tyres for split rim
Submitted: Thursday, Mar 24, 2005 at 22:57
ThreadID: 21503 Views:3566 Replies:5 FollowUps:6
Hi there,
My troopy will be needing new tyres shortly, they are standard split rim, I think 16 x 5.5". Had been using 750R16 Bridgestone Dueller AT. Could I fit 235/85R16 to these rims? Do I need new tubes? Am I better off fitting wider one piece rim with larger, lower profile tyres?
Thanks a million
Sanga
Reply By: Davoe - Friday, Mar 25, 2005 at 09:24
235x85x16 are ideal for splitties and are a good size for bush work. wider tyres on different rims may be better for sand work but could you justify the xtra expense. Change the tubes for good luck and keep the old ones as spares for the bush. Lower profile tyres would be a benifit for higher speed highway cruising - something you would only dream of in a troopie. My advice is stick with the combo you have
AnswerID: 103806
Follow Up By: sang - Friday, Mar 25, 2005 at 10:12
Hi Davoe,
Thanks for the advice. is 235x85x16 too wide for the 5.5" rim?
Sanga
FollowupID: 361316
Follow Up By: Davoe - Friday, Mar 25, 2005 at 10:27
no it is fine, plenty of work utes in the carpark with them on splitties
FollowupID: 361317
Follow Up By: Members - Greg & Gail - Friday, Mar 25, 2005 at 11:02
I have used both split rims are better in the bush and the equal of 33x12.50 on sand. Stay away from low profile tyres.
FollowupID: 361322
Reply By: Footloose - Friday, Mar 25, 2005 at 11:25
I have run 235's as an alternative to 7.50X16 on my 80 series for years. They are an excellent choice.
AnswerID: 103813
Follow Up By: sang - Friday, Mar 25, 2005 at 11:35
Hi Footloose,
They were on 5.5" split rim ?
Most of my driving is towing a heavy caravan and some bush work on its own. Planning to go to the Kimberly this year. Would 235 be scarce in that area.
Sanga
FollowupID: 361324
Reply By: Footloose - Friday, Mar 25, 2005 at 11:41
Now you've found a blindspot , I'll admit to my ignorance of wheel sizes. The 235's were put on 7.50X16 instead of the skinnies. The beauty of this arrangement is that in an emergency you can use a standard tyrewhich is availiable everywhere. Well that was my rationale. :))
AnswerID: 103815
Follow Up By: Davoe - Friday, Mar 25, 2005 at 12:16
I have been out yo the carpark for a look and it seems the 6 inch splittie is standard on the 100 series and the 5.5 on the 78s - there are 2 utes side by side one with 7.5 tyres and 1 with 235s there is maybe a slight bulging on the 235s but certainly look totally fine and
FollowupID: 361329
Follow Up By: sang - Friday, Mar 25, 2005 at 15:44
Hi Davoe,
A few web sites of tyre companies say that 235 requires 6.5" rim.
regards
Sanga
FollowupID: 361339
Reply By: Member - muzzgit - Friday, Mar 25, 2005 at 19:39
I had an FJ45 with splits and when the tyres wore out I put 235/85/16 on, but I went with BFG A/T's.
Silly really, cos standard 235's come in 6 or 8 ply ratings which offer a much tougher tyre.
My only concern may be the rust band can wear a hole in the tube if you run low tyre pressures all the time for beach driving. I never had this problem but a good mate had it happen all the time. He chucked em and went for fatties, but I would do it again if I had a bus with splits.
6 or 6.5 inch rims would be better, but lots of guys run 235's on 5.5
AnswerID: 103838
Reply By: Member - Phil G (SA) - Saturday, Mar 26, 2005 at 09:16
Most tyre manufacturers recommend 6"-7" rims for the 235/85. The splits are 5.5". But the tyres fit up beautifully on the splits so nobody bothers about the small discrepancy.
Tubes are a major issue. If you replace them with some of those thin aftermarket tubes, you may have the occasional drama with split seams and pinhole leaks. Need quality tubes - a good tyre dealer will have good second hand Japanese made tubes that have been pulled out of original Toyotas and Nissans.
And make sure they check for stickers on the inside of the tyre and remove them - another cause of holes in tubes.
AnswerID: 103876
