Legal tyre size
Submitted: Sunday, Mar 27, 2005 at 19:21
marklynn
My Narvara has 255/70/16 tyres as standard..Are 265/75/16 a legal replacement & if not what size should I go for
Ta !
Mark
Reply By: Jimbo (WA) - Sunday, Mar 27, 2005 at 21:00
Mark,
Depends on where you are as to how oversize you can go legally. But just doing the sums, you are talking about going from a rolling diameter of 757mm to 797.5 which is a 40.5mm increase; strictly speaking illegal everywhere I think!
103971
Follow Up By: marklynn - Sunday, Mar 27, 2005 at 21:29
N.S.W
361464
Reply By: Diamond (Vic) - Sunday, Mar 27, 2005 at 21:48
yes illegal in nsw.
15mm increase is all thats allowed.
103981
Reply By: Member - Ross H (QLD) - Monday, Mar 28, 2005 at 01:41
Hi mark
What jimbo is saying is more than likely right. But I own a STR 2002 model and went to the tyre size you want. Cant do it with out a bull bar as the front
wheels will rub. I like the extra clearance but your speedo will be out quite a bit ( mind you they are out 10% off the show room floor )Checked
mine before and after with GPS. I am running goodyear ATR witch are smaller in diameter than the muddies.Have also fitted series 2000
suspension and wound up torsion bars.
Car rides and handles
well. You will also notice a change in breaking and accelleration (slighty slower on start and longer to stop ).But at end of the day you are driving a 4wd not a sports car.One other thing , even if you choose not to step up remember the navara has a high towing capacity compared to some of the other mid sized utes so make shaw what ever you choose meets the load rating required. Hope I have been a bit of help
ross
103987
Reply By: Savvas - Monday, Mar 28, 2005 at 08:00
In NSW, 265/70R16 is the largest you can fit without an engineer's certificate
103995
Reply By: Shawn - Monday, Mar 28, 2005 at 09:41
As Diamaond said. You can go 15mm larger than the largest diameter tyre/wheel combination listed on your tyre placard or handbook.
Have a look at the RTA website for this. Opening paragraph is probably the most important.
"Always check with your insurance company before you make any alteration with your vehicle."
http://www.rta.nsw.gov.au/registration/downloads/vsi/vsi09_rev4.pdf
shawn
104005
