Madigan Line
Submitted: Monday, Mar 28, 2005 at 20:02
ThreadID: 21559 Views:8015 Replies:6 FollowUps:6
A group of us would like to do the Madigan Line this winter, in June if possible.
We are all running turbo diesel Landcruisers, some factory, some aftermarket.
I would like some advice and information.
How much time should we allow for the crossing. Is it OK to do it east to west. How much fuel and water should be carry. Who do we need permits off, and what are the chances of getting them, and can we by pass the sections where we are unable to get permits. Has anybody done it with off road trailers.
Simon
Reply By: Willem - Monday, Mar 28, 2005 at 20:41
Can't answer many of your questions but having done country to the west of the Madigan Line. I would say that you are pushing $hit uphill with trailers but that is your choice. There was a recent article in 4x4 Australia Mag about a similar trip. They had a major breakage with a 100 series.
Go to my website, click on 4x4 and then read The Spinifex Trail. This happened a while ago but it will give you some idea of the terrain. Once again east to west is more difficult due to the way our winds blow across the continent.
Good luck!
AnswerID: 104056
Reply By: Peter 2 - Monday, Mar 28, 2005 at 20:45
I'd allow at least a week, preferably more, probably take longer.
West to east would be better, lots of fuel and water, work out your worst consumption and take more. I had a 1hz troopy and we used nearly 25 l/100k, sometimes more.
Permits unobtainable for QLd section, and also Aboriginal land in NT.
ABSOLUTELY forget trailers, hard enough with vehicles.
Make sure all vehicles are in absolute perfect condition paying particular attention to suspension and cooling system.
AnswerID: 104057
Reply By: crowie - Monday, Mar 28, 2005 at 22:08
Simon
Firstly the Madigan Line is just that. Going overland between geographic points that Madigan recorded as he travelled on foot with camels. There is no road like the French Line. Your really have to choose your own course. There are however some more travelled parts because you can take guided tousr. Also apparently very hard if not impossible to obtain permits for aboriginal land.
I was in Birdville two years ago when a couple came in with one of the best equipped OKA's I have ever seen after doing the whole of the Madigan line. The vehicle had broken splines on the left hand side front drive shaft en route. The owner had been able to jam some timber into the hub which got them into Birdsville. He said it was literally bush bashing and log jumping and would have been easier with a D9.
If its not an offence to go to the opposition check out http://www.overlander.com.au/pg/destinations.php?dest=66.
AnswerID: 104066
Reply By: Member - Phil G (SA) - Tuesday, Mar 29, 2005 at 16:00
I did the Madigan Line last year with Aussie Tracks.
If any are the IFS 100series, I'd leave it at home. You'll break the front end on the Madigan Line. Rigid Front LandCruisers and Prados would be OK.
We took 12 days from Alice to Birdsville.
No, you won't get up the steeper slopes. When crawling over spinifex, you can't get a run up, so the dunes although not very tall, are more difficult. From teh west is the only way.
300 litres minimum for 6 cyl TDs.
You won't get permits for camps 3,4,5 and Camps 17,18,19. Andado station need to be contacted for camps 1 and 2. The section across to Colson Track and onto camp 6 is very overgrown and difficult - you'll stake a few tyres there. Camps 6 thru to 15 is crown land. Then I'd suggest you head south to Poeppels corner, and out along the QAA line. You will have had enough of walking over spinifex at a snails pace.
Forget it. Minimalist approach with plenty of the essentials is required. Once you cross the Colson track, you are committed as theres no way out until you get to camp15. Need to be fully self sufficient - no one will come to help you out there.
Its a hard trip but well worth doing for the experienced desert traveller looking for a greater challenge. Doing it with a company like Aussie Tracks is the best way IMO - they take all the hassle and worry out of. They are the only tour company willing to do the Madigan Line, and David and Joan Owen have done it 8 times, and placed the markers for the camps. No affiliation - just a satisfied customer.
AnswerID: 104158
Follow Up By: Bob of KAOS - Tuesday, Mar 29, 2005 at 17:27
I was going to say that the view of Madigans Line from the Colson Track would suggest that trailers were not an option in the wildest dream.
FollowupID: 361650
Follow Up By: Ruth from Birdsville Caravan Park - Wednesday, Mar 30, 2005 at 19:19
Hello Phil, was very much hoping one of Joan & David's mob would reply - it was a good trip, eh - but tough as. Good reply, well done.
FollowupID: 361766
Follow Up By: Member - Phil G (SA) - Wednesday, Mar 30, 2005 at 21:13
Hi Ruth,
Trip was toughish, but pleasantly so. We had no problems, and thoroughly enjoyed the experience. May even do it again next year.
FollowupID: 361780
Follow Up By: Member - Tom M (VIC) - Wednesday, Apr 06, 2005 at 19:11
Phil,
How long did it take on the Madigan itself and how much fuel did you have left?
Me and some friends are also doing it this year (latish July) and I'd appreciate any further info you've got?
Tom
FollowupID: 362546
Follow Up By: Member - Phil G (SA) - Wednesday, Apr 06, 2005 at 20:47
Tom,
Fuel used by our group was:
Prado TD: 180litres
two 105series with aftermarket turbo: 240 litres
80series and Troopie with 1Hz: 215-220 litres
this was actual consumption. Naturally you'll carry more. I had the Prado and took 240 litres; The 6 cylinder diesels took 300 litres (Alice to Birdsville). Suggested water was 100 litres/vehicle/2 people.
From memory, it took about 7 days to go from Old Andado Station to Camp 16. Best to not be in a hurry :-))
Cotact David Owen before you go. He has a great interest in the Madigan Line and will offer helpful advice too. I think his email is still:
dowen@outbackadventures.com.au
FollowupID: 362562
Reply By: Willem - Tuesday, Mar 29, 2005 at 19:17
Would just like to add that we got 8.53mpg or 33l/100km in a Suzuki 1.3litre doing the Simpson from Jervois Station to the French Line. This was around 500km of Offroad driving. Hard stuff but happy to have done it.
AnswerID: 104196
Reply By: Member - Tom M (VIC) - Wednesday, Apr 06, 2005 at 19:15
Simon,
I'm doing the Madigan as well this year, 3-5 vehicles
When are you going? Do you want to share some planning information?
Tom
AnswerID: 105439
Follow Up By: Simon - Tuesday, Apr 12, 2005 at 05:58
Tom,
Please contact me off the group at scevans@optusnet.com.au
Simon
FollowupID: 363304
