Using "Tracks" in Oziexplorer ver3.95
Submitted: Sunday, Apr 10, 2005 at 17:16
Member - Tony B (QLD)
We are going on the road for 4 weeks With Laptop running oziexplorer and I wanted to use it to log each day as a different track and different colour. is this possible. I have had a mans look through the tuitorial and help sections and didn't find much. any ideas much appreicated
Reply By: Member - TonyG (Qld) - Sunday, Apr 10, 2005 at 17:53
Hi Tony,
What you have asked can be done.
When you log a trip with oziexplorer, it saves it as a file with the default name of mmtrack,plt.
What you can do is at the start of each day before you start using oziexplorer, is locate the track which was recorded the day before, and rene that file - ie from "mmtrack.plt" to "day_1.plt", or maybe by the date of the trip - ie "24-5-04.plt".
Then when you start oziexplorer for the days trip, oziexplorer will automattically start making a new filed called "mmtrack.plt" to record the new trip.
Then just repeat the rename file process at the start of each day.
After, when you want to view the trips, you can load each relevant day, give each trip a different colour, and this will give you what you want.
Hope this helps.
TonyG
106018
Follow Up By: Member - Tony B (QLD) - Monday, Apr 11, 2005 at 18:44
Thanks heaps Tony G
It sounds all so easy when you say it like that . Once again thanks
Tony B
363235
