scanners hand held
Submitted: Wednesday, Oct 23, 2002 at 00:00
skip
Hi all
I have just purchased a hand held scanner from uniden UBC60XLT
I had no idea on that you had to input freques to make it operate
can any one help regarding emergencey freques for
sydney and
outer west /blue mountains nsw.
thanks for the help & hope to see you out there one day skip.
Reply By: Jamie - Wednesday, Oct 23, 2002 at 00:00
You should be able to pick up book on all the scanner frequencies at your local Dick Smith Electronics store. Failing that try searching for them on the net. For example "NSW Scanner Frequencies". Hope that helps a little
7788
You should be able to pick up a book on all the scanner frequencies at your local Dick Smith Electronics store. Failing that try searching for them on the net. For example "NSW Scanner Frequencies". Hope that helps a little
7789
Reply By: truckster - Wednesday, Oct 23, 2002 at 00:00
