vibration damper for 99 hilux gearbox
Submitted: Monday, Apr 18, 2005 at 20:07
howie15
hi guys hoping someone can help the damper (rubber) has broken so looking for a rebuild,or remedy, a genuine one
well dont ask surely someone must make the engine mount type bolt on part any help would be great . cheers guys
Reply By: timber - Tuesday, Apr 19, 2005 at 08:25
Howie,
Simple remedy, remove two bplts, remove damper, locate bin, file damper in bin, go have a beer.
I had the same problem, removed the damper and tossed it, no noticeable difference without it fitted.
Buggerlux
107342
Follow Up By: gforse - Thursday, Apr 21, 2005 at 10:15
HOWIE DONE THE SAME AS BUGGERLUX ON MISSUS 99 DUAL CAB NO PROB ALSO WORK FOR A COMPANY THAT HAS 100S OF LUX IN CONSTRUCTION AND MINING I AM A DIESEL FITTER AND WE CHUCK THEM OUT GARRY
364550
Reply By: howie15 - Friday, Apr 22, 2005 at 01:47
well thanks for that guys cos i cant find one anywhere so i guess everyone does the same , just a caution you can vibrate the selector plate loose and oil leaks out on on 200 km trip i lost enough oil to burn the bearings in gears 1,2, 3, just keep an eye out , thanks again
107761
