help needed with calculating fuel usage
Submitted: Tuesday, Apr 26, 2005 at 11:28
ThreadID: 22377 Views:3709 Replies:6 FollowUps:2
Hi all,
could anybody please provide a calculation to work out fuel consumption figures. I keep on coming up with a figure that appears to be to low. At the rate I have calcualted I wont need to refuel until 2008, :-)
thanks in advance
Rengatt
Reply By: Peter McGuckian (Member) - Tuesday, Apr 26, 2005 at 11:46
Dear Rengatt
Some more information would be useful here. The normal way to calculate fuel consumption is to record the number of kilometres travelled and the number of litres used. You then divide the litres by the number of 100km covered to express fuel use as Litres per 100km. For example my GU 3.0Tdi Patrol uses about 11.7l/100km on a trip and around 14.4l/100km when towing the camper trailer.
Hope this helps.
AnswerID: 108223
Follow Up By: Member - rengatt (VIC) - Tuesday, Apr 26, 2005 at 11:53
Hi Peter,
I am trying to work out the litre/per100km figure. The figures I have are 560kms on 62.3 litres of fuel. I don't know how to convert these figures to litres/per100km
Ren
FollowupID: 365029
Follow Up By: Peter McGuckian (Member) - Tuesday, Apr 26, 2005 at 11:56
Dear Rengatt
Divide 62.3 by 5.60 (the number of 100kms)
This gives you 11.13 L/100km
Not bad consumption. What are you driving?
FollowupID: 365030
Reply By: Member - rengatt (VIC) - Tuesday, Apr 26, 2005 at 12:02
Driving a Frontera 2001 model, it was the first real trip for it and we were loaded to the hilt. I have to admit that I had a good run and it was in cruise control mode for about 90% of the trip which would have helped the consumption.
Thanks for you help with calculating the usage.
Ren
AnswerID: 108226
Reply By: Member - Peter R (QLD) - Tuesday, Apr 26, 2005 at 12:15
G'day Rengatt,
If you go to Members/FileSwap/Petrol Consumption Calculator there is an excel sheet with a couple of spreadsheets for working it out
Pedro
AnswerID: 108228
Reply By: Member - Gary W (VIC) - Tuesday, Apr 26, 2005 at 12:58
I've got a calculator (of sorts) on my website - click on the rig photo below and follow the link.
Gaz
AnswerID: 108235
Reply By: Kumunara (SA) - Wednesday, Apr 27, 2005 at 00:24
If you want to calculate MPG work out your fuel usage in L/100km. Then divide 282.48 by L/100km.
AnswerID: 108366
Reply By: Member - Craig M (NSW) - Wednesday, Apr 27, 2005 at 09:06
As previously mentioned,
Check out the downloadable files that are now available in the Members File swap page. There are a few interesting files for download and there FREE.
AnswerID: 108394
