Larger fuel tank for Surf
Submitted: Tuesday, Oct 29, 2002 at 01:00
Surf
I own a 1994 Surf, which despite opinion to the contrary has been the best vehicle I have owned. The only problem is it has a very small fuel
tank - 65 litres. This gives it a range of only 400-450km around town, as the diesel engine isnt the most economical. I have heard that it is possible to fit a Patrol
tank as a replacement for the original Toyota
tank, has anybody heard of or done this? If so, can they advise what size the Patrol
tank is and any problems associated with the fitment. I am looking at fitting a long range
tank some time down the track, but this may not be such an urgency if a Patrol
tank fits.
Reply By: Truckster - Tuesday, Oct 29, 2002 at 01:00
You can use a GQ
tank, and they are 95 ltrs..
If what I remember is correct, you fit it under the rear with a little bit of work.
The problem is you need the GQ sender etc, and thats the expensive bit.. $400+... Rare as rocking horse poo at wreckers.
Longranger tanks etc are not much more than that...
7997
Follow Up By: Truckster - Tuesday, Oct 29, 2002 at 01:00
Let me rephrase that... $400 all up with fuel guage recalibrated,
tank the lot...
From another list, about a lux, presuming they are the same as a Surf.
I just finished putting one in my 84 lux last weekend, I put
mine behind the diff ( where the spare wheel carrier USED to be ) just removed this & welded two bars across the chassis.
I paid $50 for the
tank and $120 for the sender. Quoted $200 for recalibration of fuel guage, but they couldnt guarantee that it would be 100%.. Option is Aftermarket guage.
3746
Reply By: Savvas - Wednesday, Oct 30, 2002 at 01:00
A dumb question....
Isn't the Surf the same as a ForeRunner?
8014
Follow Up By: Gypsy Helen - Wednesday, Oct 30, 2002 at 01:00
No Savvas. The Surf is the imported version of the ForeRunner. Similar, but different.
3769
Reply By: Surf - Wednesday, Oct 30, 2002 at 01:00
As someone once said, Forerunners are poverty Surfs. I actually thought after posting my original question that I should have said Forerunner/Surf, as that may mean more to some individuals.
8019
Surf, I know this hasn't anything to do with your question, but how did you go getting insurance for your Surf? I bought one last Nov. and had the devils own luck getting an insurer. Finally found one, though.
3770
Follow Up By: Greg - Qld - Thursday, Oct 31, 2002 at 01:00
HI Gypsy Helen,
I've a 93 Surf and insurance wasn't a problem. Possibly it depends on the type of insurance you want (meaning how much off-road cover you want) and how much you're prepaired to pay.
I just went straight to Aust. 4WD Insurance who're now underwritten/owned by CGU. Includes cover ANYWHERE irrespective of being a road, river or within 1km of Australian Coastline - Just incase I decide to drive to Tassie and get stuck on the
creek crossing...LOL :-)
PS around $800pa including all accessories (not gear being carried)
3790
Follow Up By: Surf - Thursday, Oct 31, 2002 at 01:00
Gypsy Helen, I insured initially through RACWA for a total of $24,000, but after 12 months went through TCIS in
Adelaide as they allowed off road driving. RACWA were a little
grey in the wording of their policy regarding "endurance trials", so I switched to be on the safe side. You have to be a member of a 4x4 club, and they require a valuation by an assessor first up. From memory I paid approx $640 for $23,000, plus for a little extra, I was able to insure our
camping gear.
3807
Follow Up By: Gypsy Helen - Friday, Nov 01, 2002 at 01:00
Thanx guys. I did get
mine insured with Torque - in
Adelaide(underwritten by Lumleys) at about $800, but the mainstream insurers wouldn't handle it.
3835
Reply By: ray91 - Wednesday, Oct 30, 2002 at 01:00
Hi I have fitted 3 surf/forruners with the patrol
tank.first the tanks are free if you go to a gas lpg fitting place,patrols have the
tank removed to fit the gas
tank and the gas fitters usually throw the tanks in the bin.The
tank is easy to fit using two lengths of 30mm square bar across the chassis / tow bar.You need to make a round plate to cover the hole in the top of the
tank also remove the filler pipe on the car and cut a hole in the side and weld another pipe to it so the filler now has two pipes and one cap.Join the filler pipe to the
tank with rubber hose.I used an electric pump to pump fuel from the big patrol
tank into the fillertube for the front
tank and no gauge on the patrol
tank, Why you should know how much fuel is in there.Cost about $200 including the new pump hoses, steel bar and bolts.If you live in
Perth I can show you one on a surf Ray
8037
Sounds good Ray, I am also in
Perth, how do we make contact?
3806
Reply By: ray91 - Friday, Nov 01, 2002 at 01:00
Surf give me a ring after 8.30 tonight friday 1 Nov or tomorrow on 0419813091.I have just been to the gas /lpg fitters and i have a patrol 95 litre
tank for you free.
8093
Follow Up By: Surf - Friday, Nov 01, 2002 at 01:00
Thanks a lot Ray, I'll ring you tonight. Much appreciated
3834
