accessories
Submitted: Sunday, May 08, 2005 at 20:19
Andrew(C Bay)
i've heard on the grape-vine that u can now get a gas conversion kit for diesels. I own a 80 series cruiser, just wondering if anyone out there can shed some light on the pros and cons. Also prices and power specs?
Reply By: Kalgoorlie Escapee - Monday, May 09, 2005 at 08:19
It is called gas fumigation. You do not replace the diesel, but ad 12 - 25% extra LGP depending on the load of the engine. There was an excellent article on it in the West Australian recently Just found a copy). 26l LPG
tank and the normal diesel
tank. The article stated the guy nearly doubled his range and only used 1 LGP
tank to 2 Diesel tanks. $3000 fitted for a standard conversion, in this case a Landcruiser 100 T/D. Canges to setting can only be performed by the dealer. Can forward the document if you require
110386
Follow Up By: Kalgoorlie Escapee - Monday, May 09, 2005 at 08:27
Lovato LPG Fumigation
from Lovato Autogas
08 8340326
366917
Follow Up By: Aston - Monday, May 09, 2005 at 17:09
Hi Fellas
This might be worth having a look at.
Click on this
link text
Cheers Aston
366987
Follow Up By: Wayne (NSW) - Monday, May 09, 2005 at 17:35
Aston,
Sounds great, but i still can't get my head around the fact that there is a bottle of LPG in the vehicle that is feeding gas to the inlet manifold. A small leak at the bottle and you might end up in a few different postcodes.
Wayne
366989
Reply By: Kalgoorlie Escapee - Monday, May 09, 2005 at 17:54
No different to LPG powered vehicles. The setup in Aust not as "aggricultural" as the one in the attache document. The same standards apply to both vehicle installation types. Unlike petrol powered cars, there are no ignition sources in a diesel (that is why they are used in the mines).
110489
Follow Up By: Andrew(C Bay) - Friday, May 13, 2005 at 21:45
Thank u Kalgoorlie your info helped heaps!!!
367619
