cruise controls
Submitted: Monday, Nov 04, 2002 at 01:00
desert
Anybody with any feedback on cruise control fitted to GU Patrol with the 4.2 litre turbo diesel engine.
Reply By: OziExplorer - Monday, Nov 04, 2002 at 01:00
What do you want to know about cruise control?
I have a Command AP150 I fitted myself and works like magic.
Suggest you phone Command direct in
Sydney to find out all you need, as there are few out there that really know what cruise control and all the fittings needed. Ask for Graham/Graeme in the Technical section, and tell him what type of vehicle, model, engine etc, and he will give all the correct part numbers to the sales department. The AP150 basic kit should be around the $300.00 mark incl GST. The extras to fit your speedo etc. could come to another $100 max.
Command Auto Group Pty Ltd
12 Giffard St Silverwater 2264 (02) 9714 0900
Technical (02) 9714 0990
Sales (02) 9714 0980
Fax (02) 9714 0999
8185
Reply By: desert - Tuesday, Nov 05, 2002 at 01:00
Sounds like just the ticket. Is the unit accurate and if not, then to what extent? Are the components of a quality construction and material? Was it difficult to fit up yourself?
8208
Follow Up By: Oziexplorer - Tuesday, Nov 05, 2002 at 01:00
No, it was not at all difficult to fit, however, it did take me a fair bit of time to ensure it was all neat and tidy and properly done. It is important to mount the vacuum unit properly and in a good place to ensure the cable has a good clean path without any kinks or extreme bends. This is not difficult as the cable is of sufficient length. In my case, I mounted it on the opposite side of the fuel pump on the top of the guard on the drivers side. I will post some pictures on my website tomorrow for you and will post back with the URL.
When you say 'accurate' do you mean retains the correct speed once set. If that is what you mean, yes it does.
I wanted the proper speedo drive unit, and not the magnets on the tailshaft/driveshaft and all up, cost me $346.00.
Yes, the base model is from memory an AP50 and the next unit up is the AP60 which I would consider the minimum, and they are about $200.00.
3904
Reply By: Truckster - Tuesday, Nov 05, 2002 at 01:00
Chat on the patrol list on these.
> Got a sales letter today from nissan saying that they now sell "command cruise control" as a factory accessory and will retrofit to a 3.0td> patrol
$845.00 fitted
call you dealer if interested
Roly
Reply from bazzle, the Guru on the patrol list.
Hmmm
My Command purchased from Supercheap Auto and fitted by me cost $160 on special ($195 norm)
I guess it only the base model but it performs faultlessly
Bazzle
8210
Wow, I would fit them all day for that price. $845.00 fitted, must make it something special.
This may be the electric unit with the steering wheel controls. For that amount of money, would be interesting to see what they are offering.
3906
Follow Up By: Truckster - Tuesday, Nov 05, 2002 at 01:00
For that price, i would expect to sit in the back of the car, and sleep, while someone else drove...!
Yea crazy, but typical of car makers cashing in.. Send out a $0.10c flyer to all GU owners, and clean up with $700 profit per unit, which it would be buying in bulk!
Im on the wrong planet.
3913
