Coopers tires on a landrover
Submitted: Tuesday, Nov 05, 2002 at 01:00
ThreadID: 2292 Views:3186 Replies:7 FollowUps:3
I have series 1 landrover discovery that needs new tires.
I have heard that the coopers ST are good but the edges break away.
I have heard that the coopers STT are good but maybe noisy and not as safe in the wet on the road.
Any info regarding this would be helpfull.
Reply By: Truckster - Tuesday, Nov 05, 2002 at 01:00
Review on the Coopers ST's here... They are more like your BFG AT.
The SST is a mud tire so is going to be a little louder, you didnt mention what use you wanted the tires for..
AnswerID: 8212
Reply By: Member - Melissa - Tuesday, Nov 05, 2002 at 01:00
Hi Ian,
We recently fitted Cooper Discoverer A/T 265/75 to our GU Patrol. Went with them after looking at other options but in the end Cooper A/T's won us over with a tread pattern and decent side walls that we felt were good for both on and off road. So far, this has proven to be the case. Considered the S/T's but decided the A/T's better suited to our needs of 80:20 on/off road.
We were happily surprized with the feel of the A/T's on the car. Very smooth, no noticable road noise, look good and 80,000km warranty to boot.
Bloke I know has S/T's fitted and reckons they are more resistant to stone chips etc. STT's are really a mud terrain tyre so you can't expect the level of on road performance/feel that you would get from the A/T's or S/T's. Unless you do a lot of mud driving, I wouldn't bother with them.
:o) Melissa
AnswerID: 8214
Follow Up By: Member - Melissa - Tuesday, Nov 05, 2002 at 01:00
Oh yeah, almost forgot.Shop around for your Coopers. We found a wide variation in prices and eventually got the 4 A/T 265/75 fitted, balanced and aligned for $950. :o) Melissa
FollowupID: 3903
Follow Up By: Truckster - Tuesday, Nov 05, 2002 at 01:00
One thing with Coopers Warranty, read the fine print....
From what was discussed at our club, it ends up costing you about the same price in the long run for the rotations, and balances you have to have to keep the warranty going :(
YMMV
FollowupID: 3910
Yep, know about that. We have our tyres serviced regularly anyway and when you've had tyres wear out or separate after only 30,000km's you appreciate the warranty. :-) Melissa
FollowupID: 3915
Reply By: Cairns Offroad Training & Tours - Tuesday, Nov 05, 2002 at 01:00
I have driven on many tires in over 30 years of 4wdriving. I would rate the Cooper ST as the best compromise tire I have driven on. Comfortable soft ride despite strong sidewalls, very quiet for such an agressive tread pattern, very good on wet bitumen as they are siped and a beautiful handling steer tire. I replaced mine after 53k very hard klms and they were still roadworthy. I currently drive on MTRs and had previosly driven on BFG ATs for over 20 years.
Cheers Rob
AnswerID: 8221
Reply By: Steve - Tuesday, Nov 05, 2002 at 01:00
Coopers....well how about 30k from a set !! My dealer looked after me without a hassle... but I know he did it off his own bat.. heard him make the phone calls ...(he wasn't impressed) .....I won't be in them again !
AnswerID: 8225
Reply By: Kelly Green - Tuesday, Nov 05, 2002 at 01:00
I have ST 245 x 75 16 fitted to my Series 1 disco, great bite on the tracks, better in mud than all terrains in the a little noisy on the tar but not too much turn up the radio. I have done 20000kms and cannot see any wear. I asked Cooper directly for pressures and maintanance instructions.
Several reviews are around this web site has 1, "Truckster" mentioned another and Vic Widman trialled them as part of his tour operation acrossoz.com.au on that site BFG & ST were compared against one anther under the exact same conditions same car, same weight, and same journey.
My vehicle has Old Man Emu coils and shocks which helps fitting the larger tyre than the standard 235 x 70 16 and I know Coopers has this ST tyre now available in the 235 size but I understand there is a difference in strength.
Yes read the fine print but most manufacturers have fine print. Tyre maintanance is important rotate and balance.
You must look at what you offroading you do and evaluate you needs if you do alot of mud get mud etc.
Good luck with your purchase and enjoy,
Kelly
AnswerID: 8239
Reply By: kezza - Tuesday, Nov 05, 2002 at 01:00
Im sure you will find air pressure will play a signigicant part in reducing or extending a tyres life on a 4WD - no matter what the breed. Ive explained a few techniques for optimising pressure for weight - (just do a search about mid august and in june). Lots of theories make up your own mind.
kezza
AnswerID: 8242
Reply By: Mike - Sunday, Nov 17, 2002 at 01:00
I've a Defender TD5 with standard Michelin 4x4's fitted and they are great tyres! Why not see if you can get them for your series 1?
AnswerID: 8625
