Trailer hitch
Submitted: Sunday, May 15, 2005 at 19:36
ThreadID: 23009 Views:7145 Replies:9 FollowUps:4
HI ET AL
WE ARE looking at changing the hitch on our tralier to a more 4wd type from a 50 ml ball to be able to go off highway i know about the trig hitch we also heard of the ORAC hitch also i have heard about a Brisbane co who has a type of hitch with a great articlation could you advise as i am going to change the trailer to off road
thanks
Life MEMBER snailbait Oberon HF RADIO CLUB VKE237 mobile 7661
Reply By: Bros - Sunday, May 15, 2005 at 19:58
snailbate,
I have an ORAC on my C/T purchased from a trailer place in Beenleigh Q.
Full articulation up/down/sideways/allround. (You don't want to be in the position to have to use the last two.) The name of the mob escapes me due to old age.
Bros.
Work is the curse of the down and out bludger.
AnswerID: 111368
Reply By: Paul - OzRoamer Camper Trailer - Sunday, May 15, 2005 at 21:01
Do yourself a favour and don't stuff around - just buy the AT035 hitch from Trailer Components in Brisbane.
Not cheap but well tested.
AnswerID: 111379
Reply By: Member - TonyG (Qld) - Sunday, May 15, 2005 at 21:30
I have a Hyland 2000 hitch on my camper trailer.
It is similar to a 50mm ball hitch with a 360 articulation in all directions.
I would highly recommend it
The supplier is in brisbane
tg065
AnswerID: 111382
Follow Up By: Skinnydog - Monday, May 16, 2005 at 16:01
Here here, I did a lot of research into off road hitches and for ease of use ie: connecting hitch off road in sand , I find the Hyland to be very easy to use plus you dont need to change your tow ball over. The manufacturer is a guy named Darren Hyland and is extremely helpful. Icant remember his
contact details but he is in Brissy somewhere. Strongly recommended.
Skinnydog
FollowupID: 367799
Follow Up By: Member - Ed. C.- Monday, May 16, 2005 at 16:10
Another vote for the Hyland coupling here.... I specified same when my trailer was built, & would not consider changing to any other...
For anyone who may be interested, Darren Hyland can be contacted on (07) 3200 6261 ...
Regards, Ed. C.
Confucius say.....
FollowupID: 367803
Reply By: warthog - Sunday, May 15, 2005 at 22:05
I also have a highland hitch mkII and it is rated at 2000kg. With the correct height tow ball , mine is an ark 3500kg, the hitch tows well and is very easy to connect. Also by retaining the 50mm ball I can tow other trailers, caravans etc that are not offroad spec.
AnswerID: 111390
Reply By: motherhen - Sunday, May 15, 2005 at 23:15
We have just fitted a new AT35 from Vehicle Components QLD to our caravan.
www.vehiclecomponents.com.au
What we had previously was similar - also one with 360° swivel. We have a hayman reese for maximum articulation. VC also have a conical ball hitch; easier to hitch up with, but lacking the movement we need for sharp dips and crests.
I recently heard a tale about the friends of my cousin, whose off road trailer did a full 360° flip without harm to the car, because they had a swivelling hitch. I'd hate to roll the caravan, but with these hitches, it needn't take the car over with it.
I don't think you'll find the AT35 expensive at all.
AnswerID: 111394
Reply By: Moggs - Monday, May 16, 2005 at 07:05
That AT35 hitch looks like someone has taken an Orac and a Tregg/Trigg hitch and combined the two. Why??? Looks over-engineered to me
AnswerID: 111400
Follow Up By: Well 55 - Monday, May 16, 2005 at 08:04
Moggs that's why it is better.
FollowupID: 367745
Follow Up By: Paul - OzRoamer Camper Trailer - Monday, May 16, 2005 at 08:44
Moggs
With HIRING camper trailers we need to offer the most "idiot proof" accessories we can get - not meaning to be derogiatory - The AT035 offers a 3 was locking pin setup that fills our needs and hopefully the vehciel can't drag the trailer over if it goes - or visa versa.
It more than fills our needs all Cape York Camper Trailers come with this fitting as standard.
FollowupID: 367749
Reply By: MrBitchi - Monday, May 16, 2005 at 08:50
Snailbate,
Have a look here. Shows all the various styles available.
Personally I use an ORAC.
Cheers, John.
AnswerID: 111403
Reply By: Member - Duncs - Monday, May 16, 2005 at 08:50
Have not seen the AT035 but have used a treg for the last 8years with no problems.
Duncs.
AnswerID: 111404
Reply By: Member - Camper (SA) - Monday, May 16, 2005 at 19:47
I use a Treg which is fine for what I do. But don't confuse a Treg with a Trigg. At first sight the look the same but the Treg gives more articulation.
Camper
AnswerID: 111496
