60 Series chrome wheels to 80 Series
Submitted: Sunday, May 22, 2005 at 08:02
ThreadID: 23192 Views:4245 Replies:5 FollowUps:1
Can someone please enlighten me as to whether 60 series chrome wheels will fit on a 1996 GXL 80 series. Am looking at updating to 80 and need to keep wheels same as the camper trailer. Thanks.
Reply By: Peter 2 - Sunday, May 22, 2005 at 08:29
Basically no, they will fit on the studs but the offset is wrong and depending on the actual wheels you may foul suspension/brakes etc.
80 series have longer/wider axle housings and the wheels offset further in.
AnswerID: 112272
Reply By: Member - Phil G (SA) - Sunday, May 22, 2005 at 09:12
Depends on which chrome 60series wheels you're talking about.
The 60series Sahara chromes are 15x7, and the rear brakes on the later 80series don't allow 15inch wheels. (As well as the offset difference) (wheels will stick out about 2 inches).
The 16 inch chrome split rims from the 60series (they have the split on the inside) may fit up OK. I've had mates use the 60series splits on the 80series because they want a wider track. Given you have the GXL with flares, this may be OK.
AnswerID: 112276
Reply By: rads - Sunday, May 22, 2005 at 19:21
JB
I have some 80 series 15x7 chrome rims with tyres going cheap if interested. I'm in Perth.
AnswerID: 112333
Follow Up By: JB - Tuesday, May 24, 2005 at 08:52
Thanks rads.........I am still looking at the 80 but I am in Qld
FollowupID: 368768
Reply By: muzzgit (WA) - Monday, May 23, 2005 at 00:17
Early 80s came with 15 inch rims, first year or two. After that, 16 inch to make room for bigger brakes.
Cheaper to change wheels on da camper.
AnswerID: 112381
Reply By: Member - DOZER- Monday, May 23, 2005 at 13:32
Try one on the back...if it fits there, it will fit anywhere else...the offset is ok, but the calliper will hit usually, and only by a little bit...so grinding it is an option....
PS you can get 16x8's in 60 series offset and they fit... you can use the 15x7 on the front without a problem....but it will need to have a 11r32 tyre to be thesame diameter to the 275x75x16 tyre std on a 96.
AnswerID: 112427
