Keeing Food Warm
Submitted: Wednesday, Jun 01, 2005 at 21:06
David T
Spent the last two nights camped at Girraween - temps down to minus two!
Anyway, my question is, how do people keep their meals warm when the temperature is down into single digits? The metal plates we were using are very effective at radiating the heat away from the meals - puts a bit of a damper on your efforts to serve a delicious roast, only to have it go cold before you are halfway-through.
Are plastic plates any better?
Ta
David T
Reply By: Member - Russell B (SA) - Wednesday, Jun 01, 2005 at 21:09
No, just eat faster.
Russell
113968
Reply By: Member - Chrispy (NSW) - Wednesday, Jun 01, 2005 at 21:12
David
Jenny and I use lexan (polycarbonate) plates from GSI. It's relatively expensive, but will probably outlast us. We have noticed that food doesn't go cold very quickly because of the good insulation qualities.
Failing that - take some good old thick porcelain crockery and sit the plates next to the fire to get nice and warm before serving. Extra weight, but you wouldn't have bothered to post this question if it didn't peeve you :)
113970
Reply By: Lone Wolf - Wednesday, Jun 01, 2005 at 21:12
I remember, a long, long time ago, when my 2 were babies, we used to have these little bowls for them. The bowls were double skinned, and we used to pour hot
water into the hollow area, to keep the food warm.
Maybe a variation on this would be of the order. Trouble is with any metal, is that it is a fantastic absorber of heat,, and the heat it absorbs, is the minus 2 degrees!
Plastic will be a good start.
Wolfie
113971
Reply By: Peter 2 - Wednesday, Jun 01, 2005 at 21:21
We use melamine plates, they can be heated/warmed near the fire and do insulate better than crockery or metal.
We gave up using enamel campware years ago for the same reason, both cups and plates.
113975
Reply By: Steve - Wednesday, Jun 01, 2005 at 21:30
Heat retention in any (china) plate is dependent to a large extent on the amount of aluminium in the 'mix' !! So get in contact with a decent supplier in your area ..main city..and get a couple of good quality commercial plates..pre heat them and they will help your problem..will beat a piece if tin any day, but clearly wont stay warm forever on a cold night !!!
113979
Reply By: Mike Harding - Wednesday, Jun 01, 2005 at 21:48
There is no real solution. Two plates stacked together helps but if the meal gets too cold cover it in aluminium foil/saucepan lid (or muslin/cotton, before foil) and place it over the top of a large pan of gently boiling
water and steam it warm again - age old practice.
Mike Harding
113986
Reply By: troy35 - Wednesday, Jun 01, 2005 at 23:08
It got down to minus 2 and your worried about keeping your meals hot. I am amazed you were able to keep yourself warm in those sort of temps. I cannot even imagine
camping when it gets that cold at night.
How do you light a fire inside your tent???
114009
Reply By: D-Jack - Thursday, Jun 02, 2005 at 00:53
Cheap paper plates over the metal ones. Then throw plates (paper ones!) onto fire, no washing up and food stays a bit warmer. I would me more worried about the ambient temp cooling the food than just a bit of tin on the bottom at those sort of temps though!
D-Jack
114027
Reply By: Kiwi Kia - Thursday, Jun 02, 2005 at 07:02
Simple is best. Stand your hot saucepans on your plates for 30 seconds before you dish up the food. The heat in the bottom of the saucepan will heat your plates.
114035
Reply By: Ingenious - Thursday, Jun 02, 2005 at 21:22
I know your going to think I'm crazy BUT I just put the meal back in the Waeco 12 volt microwave oven for 2 mins & hey presto steaming hot dinner again. Works just as good when the cuppo goes cold cause somebody stops by for a chat.
I guess this doesn't help you if your in a tent but if ya got a van there worth every cent.
Cheers.
114141
Reply By: David T - Thursday, Jun 02, 2005 at 21:51
Thanks for the replies.
I had warmed the plates by stacking them at the back of the gas stove before serving up - still only helped for 2-3 minutes though...
It was quite cold, but that only gives more reason to stay close to the wife at night!
Thanks again
David T
114151
Reply By: gottabjoaken - Friday, Jun 03, 2005 at 15:45
Try getting wicker holders for the plates - sometimes people use them for paper plates - then you can really heat up the metal ones.
probably last all of an extra two minutes !!!
Just eat faster. Bettre still, eat from the pot!
ken
114242
Reply By: flappa - Friday, Jun 03, 2005 at 15:50
Eat off the BBQ plate
114243
Reply By: Mad Dog (Australia) - Friday, Jun 03, 2005 at 16:53
So you're saying the food cools down too quick because the ambient temp is very cold.
Well if thats the case then you need a higher air temp...easy....eat in your vehicle with the heater going....too easy eh!
114248
