AnswerID: 8459 Submitted: Wednesday, Nov 13, 2002 at 00:00
OziExplorer
replied:
D*ck Smith Electronics have:
Low Voltage Battery Cut-Out
Kit No. K3124
Price $29.88
From website: www.dse.com.au
Ideal for car or boat when powering external
accessories.
Disconnects the load from the battery once the voltage drops to a predetermined level
Adjustable drop-out voltage: 10.9 to 11.9 volts (nominal)
Can be set to automatically restore power to the load when the battery returns to normal condition
It is a simple kit to build.
Reply 1 of 2
FollowupID: 4098 Submitted:
Mikef_patrol posted:
Yep, have used one of these for the last couple of years, works well. Can adjust the cutout voltage via a variable resistor. Be aware though, that over rough roads, the variable resistor setting can change, so once you have it adjusted to the setting you require, put a dob of silicone on it to stop it moving.
TTFN
FollowUp 1 of 4
