chevy6.5 V8
Submitted: Sunday, Jun 05, 2005 at 22:03
ThreadID: 23611 Views:4088 Replies:6 FollowUps:8
Have gone cold on the 12Ht as a conversion for a Series 75 Toyota Landcruiser Ute. Am now seeking any info on a Chevy6.5 V8 as a conversion for the same vechile e.g performance, reliability, availability, economy
Reply By: GO_OFFROAD - Sunday, Jun 05, 2005 at 22:20
just get a good 1hdft or fte, and do that, all factory parts, and plenty of grunt, and probably work out cheaper.
AnswerID: 114484
Reply By: 12HT75 - Sunday, Jun 05, 2005 at 23:44
What turned you off the 12HT?
I am running a 12HT in a 75 - mainly because it is a bolt-in fit, same capacity so no rego hassles, proven reliability, the only mods necessary were to the intake/exhaust plumbing and using a HJ61 throttle cable.
I looked at a 6.5 V8 but decided against it because:
a) I prefer a 6 cylinder
b) I wanted a direct injection diesel
c) The engine bay in a 75 is pretty small - it looked like the V8 would be hard to work on
I must admit that the V8 would probably have more power though. As far as fuel economy, I went from approx 7km/L from a turbo 2H to approx 9km/L with the 12HT.
AnswerID: 114492
Follow Up By: rash - Monday, Jun 06, 2005 at 17:08
I had a 6.5 chevy in an f150.....when i sold it i had covered approx 400,000 K's not an ounce of trouble....had the injectors and pump done up not long before parting with it......was a very sad parting...this vehicle took me on the worst roads in aus...stock route, gulf country, cape york, simpson desert...you name it
So to your ??'s
Reliability......*****
Economy.......between 8 @ 7 K's/litre
Power......you don't need a turbo
I had mine fitted at Brunswick Diesel in W.A. and it was a new motor when fitted and was also a turbo motor(there is a diff between turbo @ non turbo) however i never had a turbo fitted
For me this was an absolutely brilliant motor
Rash
FollowupID: 370475
Follow Up By: geocacher (djcache) - Monday, Jun 06, 2005 at 23:56
Heee heee. RAOFLMAO.
I'll state my bias as a GM fan rather than Ford before I start...
You didn't finish the job you started but putting a Chev motor into a Ford truck was a good start.
If a job's worth doing however it should be done properly. Why didn't you finish it and put a Chev body around the motor....
Seriously though. We run the Chev 6.5ltr Turbo Diesel in ambulances in Vic. Dunno if I'd put one in my own vehicle. We seem to have a fair bit of trouble keeping alternators, injector pumps and FSD's up to them.
We've just got the first of our F350's and it seems pretty good so far. Another 100,000 km will be interesting to see how they're going.
FollowupID: 370535
Follow Up By: 12HT - Thursday, Jun 23, 2005 at 20:29
Peter, following on from your reply,5th June regarding me changing my mind on a 12HT I would like you to Know that I do read these comments and in fact have now purchased a 12HT. Other than intake, exhaust and throttle mods what else is there to consider?
FollowupID: 372602
Follow Up By: 12HT75 - Wednesday, Jun 29, 2005 at 01:00
G'day,
Sorry for the delayed reply, I haven't had much computer time lately.
I already had a 3" exhaust from the previous turbo install so I just had to get a flange to fit on to the turbo housing, weld this to some 3" exhaust pipe, then use a length of stainless flexible exhaust pipe to join to the existing pipe (naturally I had to cut the original downpipe off the existing exhaust).
As far as the intake goes, I had to rotate the lid of the air cleaner around a bit, cut the metal pipe that comes out the top and braze it back on at an angle, and use a 3" 45degree rubber bend to join to the crossover pipe.
The throttle cable fits straight in.
I also made up a bracket to mount the old 2H EDIC motor, and used a rod to move the fuel lever on the fuel pump to shut the engine off. This saves messing around with the vacuum operated air flap shutdown of the original HJ61.
I didn't bother connecting the glow plug wire up to the heating element in the intake because it starts OK without it.
There is a photo here that shows a bit of the intake. I will try to put some more detailed photos up if I get time.
FollowupID: 373236
Reply By: traveller2 - Tuesday, Jun 07, 2005 at 14:45
I've got amate has fitted a 6.5 in an 80 series, done by Linquip in QLD, he loves it and plenty of grunt.
My truck has a 6.2, pulls like train, very reliable and parts if needed are cheap.
If you get a fully mechanical injection motor (no turbo) they are very simple and reliable, the only electricals are the cold start advance and stop solenoid.
AnswerID: 114756
Follow Up By: 12HT - Tuesday, Jun 07, 2005 at 17:29
Thanks for those comments. What about fuel economy? Did you notice any cabin noise with the chev6.5/
FollowupID: 370599
Reply By: Dennis (Mackay) - Wednesday, Jun 08, 2005 at 18:24
Check Marks 4wd adapters, they have kits and info on these conversions
AnswerID: 114931
Reply By: 12HT - Wednesday, Jun 29, 2005 at 22:09
Thanks for the information and photo. Does this mean that these were the only mods required? Are you implying that everything else dropped into place e.g. clutch, radiator hoses and gearbox?
Cheers Brian
AnswerID: 118148
Follow Up By: 12HT75 - Wednesday, Jun 29, 2005 at 23:08
G'day Brian,
One other thing I had to modify was the heater hoses and slightly bend the bracket holding the heater tap, as you can see at the firewall on the photo. Everything else fits in without modification.
One thing I would suggest is that you get the fuel and boost set up properly on a dyno.
Standard boost is about 7psi, I wound mine up to 10psi but had to make an adjustable rod for the wastegate. I got the fuel wound up to match. I have boost starting from about 1000rpm.
Despite this my fuel consumption still improved compared to the 2H turbo - Direct Injection is much more efficient, that is why truck diesels use it.
Power also improved, especially between 1000-2000rpm.
The engine I bought was from an auto so I had to swap the flywheel over from the 2H - a straight swap (looking back I should have kept the flex-plate and dropped an auto in her :) )
Clutch, bellhousing etc all lines up no probs, that is what makes the conversion so easy.
Basically the 12HT is just a 2H with a direct injection head. There are some minor differences though:
The fuel pump is different, it provides about 1000psi greater injection pressure (I think), and it has internal bracing because of this.
I believe the crankshaft has greater diameter radiusing where the bearing journals join the webs, for greater strength.
The pistons have oil jets under them for cooling.
The oil pump in the 12HT is a higher volume trochoidal type where the oil pump in the 2H is a gear type.
The block has oil/water connections for the turbo.
That is all I can think of right now, let me know how you go with it!
FollowupID: 373336
Reply By: 12HT - Thursday, Jun 30, 2005 at 22:40
Peter,
That was a great response! All the facts are very relevant and will take them on board when fitting the12HT. What about the radiator- is the HJ75 radiator efficient enough for central NSW? If not do you have any suggestions?
Cheers, Brian
AnswerID: 118327
Follow Up By: 12HT75 - Friday, Jul 01, 2005 at 00:47
G'day Brian,
I have put a couple more photos here
Regarding the radiator, I live in the Pilbara and regularly tow a heavy trailer in 40+ temperatures and I have had no problems with the original 75 series radiator even though mine is missing one set of fins from each outermost tube. Mine runs on about 90-95 degrees consistently (mechanical VDO gauge). It runs cooler than the old 2H turbo I had.
I do have bonnet vents though (highly recommended!)
The key is to set the fuel properly. Don't worry too much about boost pressures, it is overfuelling that will kill a diesel (burn pistons etc).
FollowupID: 373513
Follow Up By: 12HT75 - Sunday, Jul 03, 2005 at 00:34
Edit:
The link above should be:
http://www.4wdlinks.com.au/gallery/12ht75
FollowupID: 373751
