megapulse battery restorers
Submitted: Monday, Jun 06, 2005 at 11:57
Bev
Has anyone used these and if so do they work and are they worth buying
bev
Reply By: ripperGU - Monday, Jun 06, 2005 at 14:20
Have used megapulse in my old hilux for 2 years and my new GU for 3 years, they DO work!
114583
Reply By: Rod - Monday, Jun 06, 2005 at 16:24
Do a search. There are articles on here saying that they work
114599
Reply By: Mainey (WA) - Monday, Jun 06, 2005 at 22:25
Bev,
I have a Megapulse series (1) on my starter battery, I believe it works, I have bought a series (111) to use with the two Deep Cycle batteries wired in parallel, as the original series (1) unit is (strictly speaking) not suitable for use in multiple battery situations..
I tested my two DC batteries over a 5 or 6 week period and the voltage in battery (a) went up by about o.6v over the time of the test.
Both batteries were out of the vehicle and were charged and discharged simultaneously as they remained wired in parallel on the 240v charger.
Indicating one battery was starting to sulphate up, or was sulphated up MORE than the other.
Eg; battery (a) was at a lower voltage than battery (b) at start of test, however at end of the test was higher than battery (b).
At the time I did not use a solar regulator with PWM.
114688
Reply By: Bev - Tuesday, Jun 07, 2005 at 16:53
Thankyou
I had read all the stuff at the megapulse site but wanted to get some
views not connected to the site
bev
114780
Reply By: Flash - Monday, Jun 13, 2005 at 23:12
Yes.
Absolutely.
They won't restore a battery which is "mechanically" buggered, but I have restored a number of batteries which appeared stuffed due sulphation and have then given a lot more service.
115624
