fuel consumption on the Canning
Submitted: Wednesday, Jun 08, 2005 at 13:16
ThreadID: 23681 Views:2472 Replies:3 FollowUps:2
There are fuel consumption figures available for the Canning, but several show approx.the same for North and South half of the trip while others show almost identical use on both legs. As the Northern part (Well 33 to Hall's Ck) is a fair bit shorter and supposedly easier on the vehicle (no dunes) I would have thought that half should take a fair bit less.
Can anyone confirm this????
It would help a great deal if on our trip (Sth to Nth) we can take on as little fuel as possible half way, due to the price.
We're running a 2.6L EFI Jackaroo, petrol and automatic.
Many thanks for any answers.
Reply By: geocacher (djcache) - Wednesday, Jun 08, 2005 at 14:40
Depends on what people are calling half way. Some people don't take on fuel at Well 33 because they have a fuel drop organised from Capricorn Roadhouse at Well 23.
I'll be uploading our fuel figures over the next few days.
You can't possibly carry enough to make that much of a difference. You will need more to do the track from Well 23 north than you will use getting to Well 23 from Willuna. I don't know where you get the idea that the trip is easy from Well 33 to Halls Creek. It is certainly easier from much further up than Well 33 but the dunes are prominent for a fair way north of Well 33. You only have to get to Billiluna anyway as there is fuel there.
Fuel at the Well 23 drop organised in April for May pickup was $2.25 per litre. At the community at Well 33 it was $2.20 per litre and not available Sundays regardless of whether you ring and try to arrange it or not. They will not open Sunday full stop.
Besides which you will need to carry more water from Well 33 north as several of the previously good wells on the north end are contaminated with sulphur after the floods of 2001-2003 raised the water table which has only just this summer gone subsided at several wells.
I'll be emailing details of which wells are stuffed to Michelle for the trek notes but I'll also do a Canning Trip Report in the forums in the next day or so.
Being a petrol you will use more fuel anyway.
Make sure you have a good spinifex blind and a wire hook. The spinifex on the north end is quite bad and you don't want to end up like the Ford Exploder.
AnswerID: 114899
Follow Up By: Member - Mike - Thursday, Jun 09, 2005 at 13:03
Looking forward to your trek notes
Mike
FollowupID: 370817
Reply By: WillTina - Wednesday, Jun 08, 2005 at 15:48
Thanks for that, Dave. Look forward to your trip notes for this.
And yes, I did mean the split at Kunawatjiri, not well 23.
Will
AnswerID: 114911
Reply By: BenSpoon - Thursday, Jun 09, 2005 at 14:11
Something to check out- I heard the other day a mining comany came through a large section of the CSR with dozers and have cleared a level track 4m wide to squeeze a drill rig though. Drilling was completed, nothing found and they packed up and moved back out. The land is still cleared, and there is no sign of rehab going to take place and it seems all above board as it occurred on unclaimed crown land.
A group in Kal has recently referred the matter to an Envoronmental Department to try and have some penalties applied to the mining company responsible, but I am not aware of anything having happened yet.
AnswerID: 115066
Follow Up By: geocacher (djcache) - Thursday, Jun 09, 2005 at 23:56
I was there two weeks ago.
The area you talk of was between Well 9 and Well 15 and there was some evidence that a grader had been in the vicinity, however we drew the conclusion that he was not being paid either by the hour or by the tonne, as I reckon he spent more time with the blade up than down. The track is not a highway as a result - we only increased our average speed to 45 or so from about 35 for this section of the track. Partly due to the grading but more to do with the fact that you are getting out of dune country into flatter terrain with rocky interludes that you have to crawl over.
There are some spots where some scrub on the side of the track has been pushed down but I wouldn't squawk to loudly about environmental damage. This area (the CSR in general) is only used by a handfull of 4wders a year - a big handfull but still only a handful.
The number that dump fuel drums, water containers, tin cans and other junk is disgraceful. The number who leave camps with the fire still smouldering or burning is criminal. The number that don't burn their toilet paper so it is dug up by dingos and spread from here to breakfast - or don't even bury it (girls...) is utterly appalling.
Many of the areas obviously recently burnt (ie. last 12 months or so) coincide with wells and other popular camping areas (like Calvert Range which has been recently cinderised) and its too coincidental to be caused by well placed lightning strikes - especially in an area that doesn't see too many ground striking lightning storms. And we are talking thousands of hectares in total from many many small and not so small fires.
It's not a national park, it doesn't even have state park status. My belief is - and someone can correct me if I'm wrong - is that there is a reserve similar to a road reserve stipulated as a particular distance (2 1/2 miles rings a bell) either side of the designated stock route.
The washaway damage and subsequent bypass tracks around washaways and flooded areas have caused far more damage than the light touch up the grader took on.
The area in question doesn't need rehab. I grew up in National Parks in Vic and have half a clue about rehab of erosion, blow outs, dunes and other areas, and if you want to do rehab work on the Canning (nearly impossible due to logistics) then the eroded areas are where you'd start. The track between 9 & 15 will be the least of your worries.
The biggest environmental damage may still be to come. I beleive from several sources (Wiluna Police included) that sometime in the very near future a charity bash will see something of the order of 125 vehicles head north up the Canning from Wiluna. Now this is not the sort of country that you can tow a semi full of portaloos through. For a trip that involves between 14-20 nights camped there are only a couple of sites to camp that have any sort of enviroloo - and these are not high volume devices.
I'd like to know what has been organised to deal with the waste issues associated with such a trip and who will be taking responsibility for any clean up which may be required after hundreds of people have camped in areas designed for 2 - 3 groups of campers at maximum.
Anyone know the answer or who is involved? I hope it's been well thought out.
FollowupID: 370904
