Talawana Track - Midway Well
Submitted: Wednesday, Jun 15, 2005 at 12:32
Richard S
Does anyone know if the
bore /
windmill (I believe it is known as
Midway Well) on the
Talawana Track half-way between the
Canning Stock Route and
Windy Corner is operational (that is, can I get drinkable
water from it)?
Reply By: Footloose - Wednesday, Jun 15, 2005 at 13:03
Iwas sure that this came up in a previous post that I can't find quickly. AFIK the answer was no, the
well is in bad shape.
115867
Reply By: desert - Wednesday, Jun 15, 2005 at 14:45
If you mean the original
Midway Well, then no it is silted over and not servicable. If you mean the
windmill and
tank on the track a little further to the east, then yes, good
water can be had from here in a large
tank.(10,000 gals).
Water is potable.
115876
Follow Up By: andy - Wednesday, Jun 15, 2005 at 15:27
how far away from the original
midway well and from the track?
371458
Follow Up By: desert - Thursday, Jun 16, 2005 at 13:05
The turn-off to
Midway Well (approx 85kms east of CSR) is virtually next to the track to the
windmill and
tank, a couple of hundred metres at most from memory, follow that in for about 5-6 kms and you will see the
tank and
windmill and the remains of somebodys attempt at a vegetable patch in
the desert!
371603
Reply By: Member - George (WA) - Wednesday, Jun 15, 2005 at 21:33
Windmill Tank is 6 km off the Tallawana track
115945
Reply By: Cam A. - Tuesday, Jul 05, 2005 at 23:07
I was there 3 weeks ago, the
tank is dry. The
windmill is turning but no
water being pumped.
Nearest potable
water would be Georgia Spring.
Burppp
Cam
119027
