100S Rear Shock Absorbers
Submitted: Tuesday, Jun 21, 2005 at 00:18
ThreadID: 24037 Views:2646 Replies:6 FollowUps:1
Last year we did our BIG trip Perth Ayres Rock Simpson Birdsville Fraser Island Cape York Gulf Kakadu Gurig Katherine Kunnunurra Broome Perth - In all 17,000 kms
Prior to the trip I had my Tough Dog Foam Cells replaced under warranty as they had failed.
I also had Polyairs fitted to support the extra weight and the Camper van. (My mate had big problems in his 80 series also towing his Camper Van crossing the Simpson - he had Polyairs fitted by ARB in Bundaberg and never had a problem after that.)
MY QUESTION IS THIS
We travelled on some roads with fairly big rocks being thrown around under the vehicle. Consequently the lower part of the rear shocks have been badly dented and the shocks are now useless. Has anyone had similar experience and does anyone know if a guard can be fitted to shield the lower part of the shock absorber.
Reply By: ADM - Tuesday, Jun 21, 2005 at 06:19
ARB make protective gaurds that mount on the rear trailing arms, this is meant to deflect any rocks from hitting the shocks that have been thrown up by the front tyres to.
Give them a call.
AnswerID: 116643
Reply By: Member - Gary W (VIC) - Tuesday, Jun 21, 2005 at 06:38
Did a simlar trip last year. I had OME shocks with the ARB guard fitted - works well.
How did the underside of your camper go? Our Aussieswag copped a hiding.
Gaz
AnswerID: 116645
Follow Up By: Trekkie - Tuesday, Jun 21, 2005 at 19:27
Thanks Gary
We had no problems with the underside of the camper
The Kimberley if fairly tough and the angled stone shield at the front of the camper deflects any rocks from the rear of the vehicle.
As we left Dalhousie, my mate with similar setup and Kimberley had a rock get caught in the disk brake on the Camper - jammed the brake on - sheared the bolts on the brake mechanism and ripped out the brake line. Crossed the Simpson without brakes and had it fixed in Bundaberg.
FollowupID: 372249
Reply By: Bob Y. - Qld - Tuesday, Jun 21, 2005 at 09:24
Trekkie,
We use 2" poly pipe, cut in half long ways, and held on with one hose clamp. Only cover the front of shock.
Poly pipe should be available from plumbers, irrigation/pump suppliers. You'd only need 150mm to do 2 shocks.
Hooroo...
AnswerID: 116656
Reply By: Jason M P - Tuesday, Jun 21, 2005 at 13:10
Hi trekki. yes i have the same problem with mine. What i use is thick rubber mat and hose clamp to hold it in place and make sure it also covers the bottom bolt. It's a cheap way and works well.
cheers...
AnswerID: 116706
Reply By: Michael_FNQ - Tuesday, Jun 21, 2005 at 17:53
Using poly pipe or rubber matting on a shock will cause it to fail under extreme conditions. A shock is just a big heat sink, it turns energy into heat thru its dampening action, if you wrap it up it will not be dissipate this heat and the heat build up will eventually melt the shocks seals.
AnswerID: 116753
Reply By: Trekkie - Tuesday, Jun 21, 2005 at 19:17
Thanks for your replies - Looks like one of the following
ARB Shield
Poly Tube
Rubber Mat
Make sure there is air flow
AnswerID: 116765
