Squeaky door on GU Patrol
Submitted: Monday, Jun 27, 2005 at 16:32
ThreadID: 24230 Views:2477 Replies:5 FollowUps:1
The rear door on my patrol squeaks very loudly as you open it. I have tried several different lubes including chainsaw oil, axle grease, graphite powder and still it squeaks.
Any ideas on how or why. Also does anybody elses rear door squeak or is mine a one off???
Pooley
Reply By: Member -Dodger - Monday, Jun 27, 2005 at 16:38
Pooley I use a sellys product called Easy Glide. It,s a pressure pack spray that does not attract dust and helps stop this annoying squeak but must be applied regularly. It also has many other uses as you will find out when you read the can.
Cheers Dodg.
AnswerID: 117740
Follow Up By: angler - Monday, Jun 27, 2005 at 16:50
You don't mean like,,, KY jelly ???
Thanks I wil try it out. Anything that lasts more than a few weeks will suit me fine.
FollowupID: 373057
Reply By: Member - Andrew(WA) - Monday, Jun 27, 2005 at 18:46
make sure you spray into the rear door onto the joint and runner that prevents the door from swinging open too far.
This is what sqeeked on mine. I thought it was the hinges but it wasn't!
If you have already done it...I'll shut up now!
seeya
AnswerID: 117768
Reply By: Dwayne - Monday, Jun 27, 2005 at 20:20
Hey mate,
Mine had the same problem I used "holden spray grease" and have not heard a squeak since.
Dwayne
AnswerID: 117787
Reply By: Member - Jim M (NSW) - Monday, Jun 27, 2005 at 21:10
how ya going mate ? yeah mine was the same i soaked mine in wd40 then the next time i give it a gut full of spray grease not sure which one worked but i havent heard it for ages now. you watch i'll get in it tomorrow and it'll be there. cheers.
AnswerID: 117799
Reply By: Member - Cocka - Monday, Jun 27, 2005 at 23:24
There are 2 doors but I'll bet your talking about the big one with the spare on it. Due to the weight of the wheel etc the stay/keeper bar at the bottom that holds it open has to be very strong to do its job, otherwise you'd be complaining of it crushing you cause it keeps slamming shut on the back of your scone.
You have to get the lube in between the spring slides.
AnswerID: 117824
