Air Compressors
Submitted: Tuesday, Jun 28, 2005 at 19:57
Member - Barrie
Hi all Thanks to evereyone who replied .Finally bought a Thomas big red bit more than I expected to pay{$450.00} but at least I know it works
well.Bazza
Reply By: Member - Poppy (QLD) - Tuesday, Jun 28, 2005 at 20:05
Barrie
Got a mate with one of those and he swears by it, so I think you have made a good choice, but I will stick with my Bushranger
Cheers Poppy
117953
Reply By: Trekkie - Tuesday, Jun 28, 2005 at 23:50
Thomas Big Red does a good job
I have had
mine for about 7 years - took it out of my original 4WD and fitted it to my 100S.
Occasional problem I have is that it overheats and cuts out. I usually throw a wet rag over it and keep it moist to cool it down. Has anyone had this problem ?
117993
Follow Up By: Member - Jeff M (WA) - Wednesday, Jun 29, 2005 at 15:43
That's the difference between the Bigred and the Bluetounge, both are thomas compressors but the bluetounge has a fan cooled motor to prevent the over heating you talk about.
Good compressors though, Thomas make some of the best around.
Have you thought about hooking up a 12vdc high powered fan to blow through the vents onto the motor? Could solve the problem... Might be a little tricky to setup with positioning the fan etc, but might be worth a look. You can buy little fans from Jaycar, Dicksmith etc. Dicksmith do a 90mm 50CFM thats moves a far amount of air for bout $20.
373273
Reply By: Member - Brian (Gold Coast) - Wednesday, Jun 29, 2005 at 17:58
Barrie,
Bought an Ox a few months back which is a Thomas pump as
well, Big Reds "little" brother... takes 5 minutes per tyre to pump my 33's up from 18 to 40 psi... get's a little hot, not to cut-out point though... I am real happy with it. you'll have trouble free air for years!!
118085
