by pass oil filters
Submitted: Tuesday, Jul 12, 2005 at 17:24
al
hi all
can anybody tell were i can get one of these oil bypass kits.
tried all the local car part
places all heard of them but don't know where i can get one.
ive tried the guy in
stansbury in sa but doesn't want to know about it now.
any info would be appreciated.
regards
al
Reply By: Eric from Cape York Connections - Tuesday, Jul 12, 2005 at 17:48
Is it the one from the transfer case to the gear box on a 60 series toyota.
All the best
Eric
119999
Reply By: muzzza - Tuesday, Jul 12, 2005 at 21:32
type in "bypass oil filter" in google search engine
mine is an oilguard from america. works
well and is easy to change the filter
regards muzzza
120043
Reply By: Michael ( Moss Vale NSW) - Tuesday, Jul 12, 2005 at 21:35
Ring Filter Technology in Rutherford NSW, The main unit is about $130 and the fitting kit is about $60. The
toilet roll filter is about $5 if you want to refill yourself or about $12 fittet to a new top housing. Base housing is cast aluminium. I use a car type on my 4.2 Patrol. its a bit to small but the bigger unit is way too big. I just change it more often,, every 3000ks, In petrol engines the oil stays honey coloured , just like new, so they definately work. The diesel still goes black because of the high amount of carbon that passes the rings, but is still clean, You can then extend the life of the spin ons and the oil, make it work for you and save you money. Hope this helps, Michael
120044
Follow Up By: Michael ( Moss Vale NSW) - Tuesday, Jul 12, 2005 at 21:54
Forgot to mention, my wifes Patrol has 330,000ks and engine is like new, fitted by pass from new. michael
375090
Reply By: Muddy 'doe (SA) - Wednesday, Jul 13, 2005 at 00:28
A member on here called Roachie can tell you all about these things - he just installed one on his GU. He is crossing the
Simpson Desert this week so you may need to wait a bit!
He posted a couple of times on his experience with it (he loves posting on this
forum!) so have a search in the previous posts and you may find what you are looking for.
Muddy
120078
Reply By: G.T. - Monday, Jul 18, 2005 at 11:56
al --- see posts 15993 , 16027 , 17991 , 18255 , before you part with your hard earned . Units with conventional filter elements would be ok in my opinion, but
toilet roll units are ( again in my opinion ) are not worth a S--T.
Regards G.T.
120905
