Swivel Housing Boot Cover
Submitted: Tuesday, Jul 19, 2005 at 14:38
bundyman
How's this for a niffty idea.
http://www.gearingdynamics.com/cvboot.htm (sorry don't know how to do the fancy auto link)
For those of us that have a live axle front end and spend alot of time off road this little invention could be a good long term saving. Reducing the amount of grit/abrasives/
water in here is a real plus. Not sure on the cost but wouldn't think it would be much and looks simple to fit.
Hughesy
Reply By: 120scruiser - Tuesday, Jul 19, 2005 at 18:03
FYI
To post a link just copy and paste the link reference below ( link text)
Then delete everything between the inverted commas and paste in the link address. Where it says link text you can write whatever you want.
Example E Bay
121157
Follow Up By: 120scruiser - Tuesday, Jul 19, 2005 at 18:06
That didn't work how I wanted it to.
If you click on post reply and look at the bottom of the box you will see TO POST HYPERLINKS.
Just copy the one that says FOR LINKS and replace everything in between the inverted comas with the link address. Including the
http://www????????????????
Then type whatever wording you want where it says link text.
Have a couple of practice goes and you will get it.
It makes it much easier.
376204
Follow Up By: japmel - Tuesday, Jul 19, 2005 at 20:51
here you go
376241
Follow Up By: japmel - Tuesday, Jul 19, 2005 at 20:53
Thats the first time I have done that I just had to see if it works.
Thanks 120scruiser.
japmel
376242
Follow Up By: 120scruiser - Wednesday, Jul 20, 2005 at 08:07
It works.
You got it.
376274
