Site Search
Section Image
Towing,what gear?
Submitted: Monday, Dec 02, 2002 at 00:00
Member - Ray
While discussing towing with the GU the other day someone suggested it was not neccessary to stay in 4th gear as my trailer only weighs a bit under 800kgs loaded.
What is the correct thing to do according to those who tow a lot?
Hope to get a good bit of info on this topic. Ray.
Advertisement
ThreadID: 2517 Replies: 5
Views: 678 FollowUps: 3
AnswerID: 9236   Submitted: Monday, Dec 02, 2002 at 00:00
OziExplorer replied:
800kg is chicken feed for a Patrol. Don't labour/lug the engine is the prime requirement. I tow a 1,470kg trailer in 5th gear in the 2.8L diesel Triton and wack the cruise control on.
Reply 1 of 5
FollowupID: 4643   Submitted: Tuesday, Dec 03, 2002 at 00:00
Ray91 posted:
was the question asked in regards to the iffy 5th gear in the patrol ?
AnswerID: 9237   Submitted: Monday, Dec 02, 2002 at 00:00
ken d replied:
Ray
Each situation is different, obviously a light but large trailer is hard to pull in the wind, a heavy trailer hard on the hills.
Generally I say is whichever gear requires less throttle.
If you find you're in 5th with your foot burried into the floor shift back to 4th.
This said there are generally no downsides to continuously running in 4th. A little extra noise but otherwise it's putting less load on the engine and box.
Ken.
Reply 2 of 5
AnswerID: 9264   Submitted: Tuesday, Dec 03, 2002 at 00:00
Will replied:
Ray,
It really depends on the configuration but as a rule, fifth gear is not designed to haul, it is an over drive and sits on the side of the gear train and through very small (comparatively) bearings and fine teeth to keep it quiet.
A 6 cyl 2.8 Patrol would not have much trouble with fifth because it is a six cylinder and the ratios are very low ie: 3600rpm at 100kms.
The 3.0L patrol is the worst because it is a four cyl with lots of torque, which means that the torque for each stroke is greater.
You can still tow in fifth, but as soon as a hill comes up (even if you have the power to stay in fifth), change back to fourth.
Will
Reply 3 of 5
AnswerID: 9270   Submitted: Tuesday, Dec 03, 2002 at 00:00
Member - Melissa replied:
Hi Ray,
We tow an offroad camper trailer with our 4.5L GU Patrol (manual). We don't hesitate to use 5th for highway cruising. The GU barely knows the trailer is behind it. Obviously, we knock it back to 3rd or 4th as the need arises.
:o) Melissa
Reply 4 of 5
FollowupID: 4653   Submitted: Tuesday, Dec 03, 2002 at 00:00
Peter posted:
Hi Melissa,
Reading through replies to Ray's question I read where you own a 4.5
Patrol, I am at present looking at the different options Nissan Patrol present ( 2.8lt diesel & 4.5lt petrol - 3lt diesel & 4.2lt diesel are out of my price range ) can you please supply me with some feed back on your 4.5lt e.g. Reliability,Performance,Economy etc.
Peter.
Activities Index
Cairns Shopping Tour Cairns Shopping Tour
Cairns and Tropical North QLD - QLD
Air-conditioned coach transfers from your accommodation to DFO Direct Facory Outlets + Cairns Candle
Personal One on One Surfing Lessons Personal One on One Surfing Lessons
Sydney - NSW
Imagine having the opportunity to surf with one of Sydney's most professional surf teachers one on o
Barista Basics Course - Sydney Barista Basics Course - Sydney
Sydney - NSW
Are you passionate about coffee and want to learn how to make really great coffee?
Simply Sumptuous Cooking Class Simply Sumptuous Cooking Class
Sydney - NSW
Our simply sumptuous cooking classes are where you can enjoy creating and devouring a delicious 3 co
Book Now - Things To Do
AnswerID: 9289   Submitted: Tuesday, Dec 03, 2002 at 00:00
Mudguard replied:
g,day Ray i drive a 2.8 GU and tow a camper trailer and when loaded for extended trips the GVM is fairly high This model has the lighter gearbox but will pull the weight no problems just match the speed for the gear and not labour it in 5th.To answer another question the 2.8 lt (6cyl) is lighter than the 3.0lt (4cyl) has a greater carrying capacity smallerturning circle and with the addition of a unichip and bigger exhaust is quite capable on and offroad. cheers.
Reply 5 of 5
FollowupID: 4660   Submitted: Tuesday, Dec 03, 2002 at 00:00
Member - Ray posted:
Thanks all. My GU is a 4.2turbo and I don'teven know it is on the back when i'm travelling. The topic cameup "under Ale" at a barbie.
