Site Search
Section Image
Toyota hilux sr5 exhaust leak - HELP
Submitted: Tuesday, Aug 02, 2005 at 14:33
Boc1971
I have an exhaust leak that i can not find - here is the scenario and what i have to locate it so far --
Exhaust leak can only be heard when motor is under load , ie you will not hear it when idoling, rev whilst in neutral - no exhaust leak evedent - hit the road and its instantly there - it almost sounds like an individual cylinder leak as its not a contant leak sound but every 6th fire ( if you know what i mean ?)
now - whilst i had a friend block the exhaust with his foot to allow pressure to build in the exhaust system - i got a spray bottle and sprayed around every where there are gaskets and a point of a possible leak ( with soapy water ) --- found a very small leak between the cat and the header pipe -- so fixed that ( but not the problem )
One of my customers ( chatswood toyota ) suggested it may be the power valve that goes from the exhaust to the intake manifold - the noise does sound like its comming from drivers side of car - i can not see any evidence of leak - tried to put the car in gear and load up with hand break on , but can not get same results as ON road
has anyone else had this problem before ??? can anyone suggest anyting to me ????
Car is a 93 Toyota Hilux waggon - 3 Litre v6 SR5
thanks
Frank
sydney Pumps
Advertisement
ThreadID: 25283 Replies: 6
Views: 909 FollowUps: 2
AnswerID: 123356   Submitted: Tuesday, Aug 02, 2005 at 14:56
Unbreakable replied:
Has truck got a snorkel??????
Sometimes under accellaration you can here resonating niose from intake air being drawn in & sounds like an exhaust leak.......
Wet a rag & hold on exhaust to get a better seal to check for exhaust leaks.
Good luck
Reply 1 of 6
AnswerID: 123366   Submitted: Tuesday, Aug 02, 2005 at 16:19
Member - Luxoluk replied:
check your exhaust maifold for a crack??
Half way across the Anne Beadell
Click Image to Enlarge
Illkurlka Roadhouse
Reply 2 of 6
AnswerID: 123413   Submitted: Tuesday, Aug 02, 2005 at 19:08
Boc1971 replied:
HI guys , motor is Petrol , so no need for snorkel - if there was a crack in the manifold - would'nt it be evident when i plug the exhaust and squirt soapy water everywhere ?-you can hear exhaust building up a LOT of pressure and no leaks around the manifolds at all ( took of heat sheilds for better viewing access as well as side pannel in wheel arch ) it only makes noise on road test NOT on driveway test INC reving motor ...
Frank
Reply 3 of 6
AnswerID: 123419   Submitted: Tuesday, Aug 02, 2005 at 19:29
Member - Nick (TAS) replied:
As said before,I'd have a really good look at the manifold for a crack.
Our Camps - Australian Mainland
Our Camps - Mainland Australia
Reply 4 of 6
Activities Index
Sydney Discovery Teambuilder Sydney Discovery Teambuilder
Sydney - NSW
Get your team out of the office and into the fabulous Sydney outdoors on this action-packed, energis
Dolphin and Seal Swim Dolphin and Seal Swim
Mornington / Bellarine - VIC
Swimming with wild dolphins and seals is an awesome experience.
Two Car Rally Blast - VIC Two Car Rally Blast - VIC
Melbourne - VIC
Are you ready for a real rush?
Blue Dolphin Full Day Whale Watch Blue Dolphin Full Day Whale Watch
Fraser Coast - QLD
Come whale watching and experience the trip of a lifetime as you see the whales eye to eye.
Book Now - Things To Do
AnswerID: 123467   Submitted: Tuesday, Aug 02, 2005 at 22:18
Member - Matt Mu (Perth-WA) replied:
Frank is there extra (?) soot around the EGR valve...sometimes than can stick and leak out under load!
Otherwise I would be thinking...exhaust manifold...sometimes VERY hard to see a crack even when the manifold is off and in your hands.
Goodluck with it!
Matt.
The Rig
Lessons in life are free but if you have to be taught something, its usually costs you!
Reply 5 of 6
FollowupID: 378514   Submitted: Wednesday, Aug 03, 2005 at 07:40
Boc1971 posted:
HI there , thanks for your reply. Unfortunatly there is no soot evident anywhere -- i have taken a VERY good look around - runnining my finger al over manifold and egr valve to find even slight traces of soot - but alas , nothing .... If the exhaust manifold was cracked - there would be soot evident in the heat covers right ??? there as silver as the day they were pu on the vehicle - no discolouration at all
may have to spend a weekend on this thing :(
Frank
FollowUp 1 of 2
FollowupID: 378657   Submitted: Wednesday, Aug 03, 2005 at 19:03
Member - Matt Mu (Perth-WA) posted:
Frank..I would like to say yes but alas..NO! There doesnt always have to be soot present on a crack ie lots of it! I replaced a Feroza manifold (huge cracking culprit) and there was nothing but a hairline black line...yet it whislted like a banshee!
I have also had the unfortunate experience of chasing a tapping noise on a VS commodore with sportes exh and extractors..Ended up being the slightest leak across a tiny portion of the exhaust gasket where the headers bolted up. No soot or anything evident!
Have yoiu tried having someone move around the vehicle..ie front seat then middle then back to help in pinpointing the origin of the noise..it might help with diagnosis if you knew its engine, not y pipe, cat or muffler.
Goodluck mate, sorry cant be more help!
Matt.
The Rig
FollowUp 2 of 2
AnswerID: 123606   Submitted: Wednesday, Aug 03, 2005 at 16:33
Utemad replied:
On my Rodeo whenever I have a sound exactly like you have explained it is always the flange gasket. The one between the manifold and the pipe.
I have replaced it about 5 times in 4.5 years. Not lately though (fingers crossed).
Reply 6 of 6
