AnswerID: 123487 Submitted: Wednesday, Aug 03, 2005 at 06:29
Stew53
replied:
Gday
This wont get you any more power (maybe a poofteenth) but it may save you money on an engine rebuild, the engine sump in the Hilux does not have a very big oil capacity and in hot
weather and towing a trailer the oil temp will get extremely hot, I would suggest installing an engine oil bypass filter to help minimize oil oxidization by removing soot contamination and increasing oil capacity.
Filter Technology sell them, I would suggest the FM02 because of its larger oil capacity.
Some years ago I had a diesel van and I installed a few gauges one being an oil temp gauge, the gauge barely moved around town in an ambient of 35-40 degrees but once on the open road fully laden the temp rose to over 150deg (125-135 would be ideal) 150deg will kill an engine, the only way to lower the temp was to travel at 80kmh, what I did after the trip was install a bypass filter up front on the roobar (good air flow), after that the oil ran at 125deg C in an ambient of 45 deg it has since been on three of my later cars. Money well spent, I have also installed the same filter as a fuel filter, but that’s another story.
Stew
Reply 4 of 5
