Section Image
80 Series Driver's Door won't open
Submitted: Wednesday, Aug 03, 2005 at 14:48
Member - Jack
Hi guys ...
Had a mispent youth ... learned how to crack vehicle door locks ... ???
Well, I need your help.
Over at the hardware store this morning and went to lock my 1991 80 Series Cruiser GXL, and the key felt "funny". On further examination, the key locked all doors, but now does not unlock the driver's side door. ( Note: I have Central Locking).
I thought I'd come home, get the door trim off and take a look. Got as far as removing the electric contol panel and the trim around the door handle and there it stops. As the door won't open, I cant wrestle the door trim off.
Is there any "trick" I can use to get into the lock from the inside of the car to get the door open so I can remove the trim and find what the fault may be. The fault is probably some lever that has become "unattached" inside the door, as everything else works..
I am sure it is easier if your engine just blows up ... gotta be an easier job that this.
Thanks in advance.
Jack
Honk if you love peace and quiet.
ThreadID: 25317 Replies: 8
Views: 547 FollowUps: 7
AnswerID: 123581   Submitted: Wednesday, Aug 03, 2005 at 14:49
Member - Jack replied:
PS; I will grant you immunity for any information given.
Jack
Reply 1 of 8
FollowupID: 378593   Submitted: Wednesday, Aug 03, 2005 at 15:22
Ron173 posted:
Jack,
Not that I had a mis spent youth, but...
I once had a vehicle locked with keys in, and had it opened by a mechanic.
The device he used was a thin piece of steel, like shim plate only about 1mm thick, like a school rule, approx 12" long and about 1" wide, on one end had a couple of 'vee' sections cut out of it on the length of it.
Idea is, you insert said tool or similair down between the rubber and the window glass and then attempt to hook onto the mechanism and pull up.
My vehicle had central locking and the bloke opened it in 30secs flat!!
Good Luck
Ron
AnswerID: 123589   Submitted: Wednesday, Aug 03, 2005 at 15:30
Truckster (Vic) replied:
Remove the trim off the other front door, see how it works inside, then break into the door that wont open.
Reply 2 of 8
FollowupID: 378610   Submitted: Wednesday, Aug 03, 2005 at 16:14
Member - JohnR (Vic)&Moses posted:
Bruce, you could borrow my highlift jack to lend a hand
On the way to Gemtree
Click Image to Enlarge
Who?
Multi famam, conscientiam pauci verentur
AnswerID: 123628   Submitted: Wednesday, Aug 03, 2005 at 17:55
Willem replied:
Does your Cruiser have a Central Locking, Lock Switch on the drivers door?
If you have one then activate that a few times to open the drivers door.
Electrical things confuse me too lol
Simpson X country 1987
Dunerunner
Reply 3 of 8
FollowupID: 378656   Submitted: Wednesday, Aug 03, 2005 at 19:00
Member - Jack posted:
Thanks Willem, but I have done that and it does not respond. Something weird is happening in there. Might end up giving to a mechanic and let him worry about it.
Jack
AnswerID: 123636   Submitted: Wednesday, Aug 03, 2005 at 18:04
Shaker replied:
Go and park it outside the Crown Casino!
Reply 4 of 8
FollowupID: 378655   Submitted: Wednesday, Aug 03, 2005 at 18:59
Nothing like a little lateral thinking. Thanks.
Jack
Activities Index
Microlite Joy Flight - 45 Minutes Microlite Joy Flight - 45 Minutes
Fraser Coast - QLD
Experience a 45 minute microlite flight over the islands of the Great Sandy Strait, then over to Moo
Kuranda Scenic Rail & Skyrail Great Value Day Tour Kuranda Scenic Rail & Skyrail Great Value Day
Cairns and Tropical North Queensland - QLD
Complimentary hotel pickup to historic Freshwater station for reserved seating on the Kuranda Sceni
Stand Up Paddle Board & Play Stand Up Paddle Board & Play
Melbourne - VIC
Learn to Stand Up Paddle Board then get a few hours practice in!
Kangaroo Island Cruise Kangaroo Island Cruise
Adelaide and Adelaide Hills - SA
Sea voyage the Backstairs Passage from spectacular Cape Jervis to this sailing shipwreck island, hom
Showboat Dinner Cruise and Show Showboat Dinner Cruise and Show
Sydney - NSW
The Showboat spectacular!
Phillip Island Penguin Parade day tour Phillip Island Penguin Parade day tour
Melbourne - VIC
Our tour to the Phillip Island Penguin Parade includes a guided tour of the amazing Australian Garde
Green Island Cruise - Pak 2 Full Day + Coach  11am Green Island Cruise - Pak 2 Full Day + Coach
Cruise to Green Island in comfort aboard a modern air-conditioned catamaran.
Uluru Sunset Tour Y11 Uluru Sunset Tour Y11
Alice Springs and Central Australia - NT
Travel with AAT Kings to the Uluru sunset viewing area and enjoy nibbles and a glass of wine as the
Prison Life Tour Of St Helena Island Prison Life Tour Of St Helena Island
Brisbane - QLD
Travel back in time and experience the life of prisoners through the stories told by prisoners and w
John Coles - Oberon  Fly Fishing  3days/2nights John Coles - Oberon Fly Fishing 3days/2nigh
Orange and Central NSW - NSW
Let John Coles Fly Fishing guide you, chasing Rainbow and Brown Trout.
Book Now - Things To Do
AnswerID: 123668   Submitted: Wednesday, Aug 03, 2005 at 20:06
Moz replied:
Jack,
Does the inside lock button move or is it seized in the lock position?
Moz
Reply 5 of 8
FollowupID: 378697   Submitted: Wednesday, Aug 03, 2005 at 22:28
Hi Moz:
The lock button moves, but the door does not unlock. I *think* the Control arm (or whatever it is called) has come unstuck. The movement of the lock is not as smooth or as free as the other locks in the car.
The biggest problem is caused by the fact that the door can't open, which makes getting the door trim off almost impossible (for me) because the trim goes behind the cowling on the front. I am even considering taking the door off at the hinges to "get at it".
Jack
FollowUp 1 of 2
FollowupID: 378700   Submitted: Wednesday, Aug 03, 2005 at 22:37
Bit of supplementary info - the key does not seem to move fully to the "Unlock" position, even though the remaining 3 doors do unlock. Weird stuff.
Jack
FollowUp 2 of 2
AnswerID: 123671   Submitted: Wednesday, Aug 03, 2005 at 20:35
Horacehighroller replied:
G-day Jack,
I have had a similar problem with my 80.
In my case, as well as the key and central locking not working you can not move the "unlock" lever on the inside of the drivers door.
If that's your problem it's simple.
Open the window and from the outside put gentle "unlock" pressure on the interior "unlock" lever.
While maintaining pressure slowly raise the exterior door handle.
Release both slowly and you're in action.
The problem CAN be caused by (accidentally) "flicking"the outside door handle rather than releasing it gently.
Good luck Peter L
Reply 6 of 8
AnswerID: 123712   Submitted: Wednesday, Aug 03, 2005 at 23:05
Member - DOZER replied:
If all else fails, take out the drivers seat so the trim can be got out...
b4 you bag me out, walk a mile in my shoes, then your a mile away and have my shoes :)
Reply 7 of 8
FollowupID: 378715   Submitted: Thursday, Aug 04, 2005 at 06:59
Hi Andrew:
Yep - that look to be the best option. Looking at it again last night, I am starting to form the opinion that the problem is in the cylinder, as all the moving parts (that I can see) still move. I just can't get the key to fully tourn to "Unlock". But I shall perservere, as I would like to be able to open the door again.
Thanks for your help.
Jack
AnswerID: 123877   Submitted: Thursday, Aug 04, 2005 at 21:42
Many thanks for all your help and advice.
Problem turned out to be a broken spring in the lock. Got to it by removing the chrome strip at the top of the window. All good now .. no more gymnastics getting in and out.
Jack
Reply 8 of 8
