Codan 9323 programming
Submitted: Friday, Aug 05, 2005 at 01:15
MajorM
I was browsing the archives for info. and saw a Post 14095. Greg Harewood (W138) mentioned he had had his 9323 programmed for $40 in
Perth. Can anyone tell me who/where or how to contact Greg harewood?
Reply By: PeterDarwin - Friday, Aug 05, 2005 at 13:09
Are you any good with electronics?
You can program them yourself, but you do need to open the unit up.
And you can only program channels that you can legally transmit on
123956
Follow Up By: MajorM - Saturday, Aug 06, 2005 at 20:40
Hi Peter,
Thanks for the reply. Yes I am good with electronics. I am able to program Tx/Tx channels OK. For some unknown reason CODAN do not allow you to set Tx freqs above 26.5Mhz even though my set has all 40 27Mhz CB channels. Is there some way around this restriction as I would like to add Marine band 27Mhz channels.
Ron (MajorM)
379054
Reply By: Member - John (Vic) - Friday, Aug 05, 2005 at 19:28
Reply By: Mike DiD - Saturday, Aug 06, 2005 at 16:49
By inserting a link inside the transceiver you can Program new memory channels that you will be able to Transmit on.
Go to the Yahoo group for details.
124091
