Mobile phone install - CDMA
Submitted: Friday, Aug 05, 2005 at 15:57
Member - John (QLD)
Installing a CDMA for touring in the Disco and wondered if anyone else had put in a car kit with the cradle. Any ideas on where to put the damm thing without buggering something. It's a 6225 Nokia.
Any pics would be great.
Reply By: garrycol - Friday, Aug 05, 2005 at 16:19
I mounted
mine on the side of the transmission tunnel near where your left knee rests when driving. I made up a block of balsa wood that fitted over the raised edge of the centre console (the wood can be easily shaped to the same profile as the edge of the console) and painted it semi gloss black so it looked like plastic and glued it to the raised edge of the console - that way there are no holes. I then mounted the cradle to the block of balsa - the cables run in the console and come up under the non - slip mat - again no holes are needed - worked fine for me and when I sold the car I just broke off the balsa and used a bit of turps to remove the contact adhesive on the centre console - worked a treat. I put the microphone in the map holder above the sunvisor using velcro and mounted the speaker under the instrument console on the left side of the steering column using double sided tape.
123977
Reply By: Member - Sam (NSW) - Friday, Aug 05, 2005 at 16:21
John,
if you have the cradle and dont want to drill into the dash, www.dashmount.com.au have some nice no drill brackets.
cheers,
Sam.
123978
Follow Up By: Member - Jeff M (WA) - Friday, Aug 05, 2005 at 19:07
Oh man, how cool! Wish I had a known bout them when I put my GPS and Phone Kit in!! DOH!
Oh
well... I figure by the time I'm finished with the surf it won't be worth S%^T weather I have holes in the dash or not ! LOL!
378969
Follow Up By: itisi - Friday, Aug 05, 2005 at 22:52
Agree with you there Jeff. Would have been nice for the Nokia 2280.
But it's not too bad where it is, behind 4WD lever next to drivers
seat.
And reckon about the same with the Surf (unless power ball comes up).!!!
378995
Reply By: Richard - Friday, Aug 05, 2005 at 21:23
Can't help with the Nokia 6225.
Bought the Nokia 6255 whicn was/is the? the first bluetooth CDMA and has voice activated dialup. Also purchased a supertooth mobile hands free. I just activate the supertooth which is attached to the sunvisor by pressing a button and with the phone still in my belt holster make a call. I say "Home" and it dials
my home phone number which when answered I can conduct a handsfree conversation.
124014
Follow Up By: Member - Jeff M (WA) - Monday, Aug 08, 2005 at 11:12
Yeah but that doesn't give you the external antenna then does it?
379179
Follow Up By: Richard - Monday, Aug 08, 2005 at 18:29
Jeff,
You are probably right however I haven't looked into it. Had an external aerial on the previous CDMA but it only gave me an extra 10KM radius from the cell. Problem I found on a recent trip was
places like
Oodnadatta,
Birdsville, Inaminka and Camerons Corner don't have a cell anyway. Good to see
Tibooburra now has one. Hopefully the Nationals will push a hard line with the Liberals when Telstra is sold off for better coverage outback.
Regards Richard
379242
