Arrid Twincharge Battery Charge Control BCTC20
Submitted: Saturday, Aug 06, 2005 at 20:57
ThreadID: 25399 Views:3590 Replies:9 FollowUps:13
Hi I have just been given a quote of $299.00 for this item. Is this an excesive price to pay for this equipment??
Reply By: rolande- Saturday, Aug 06, 2005 at 22:32
G'Day Ray,
What exactly do you want to charge??
Redarc battery isolators usually retail for under $150
Rolande
AnswerID: 124130
Follow Up By: Mad Dog (Australia) - Sunday, Aug 07, 2005 at 18:09
It's not an isolator but a 12 volt input 14.8 volt output 20 amp battery charger.
FollowupID: 379115
Reply By: CubCamperMan - Sunday, Aug 07, 2005 at 15:26
damned excessive
mate a redarc is a better bit of gear for less than half price
AnswerID: 124193
Reply By: Mad Dog (Australia) - Sunday, Aug 07, 2005 at 18:07
That's about the going rate for that device
AnswerID: 124203
Follow Up By: Ray Bates - Monday, Aug 08, 2005 at 09:09
Hi. What I understand is that the Arrid----------- is suitable for the application that I need but I believ that the Redcar is just a gloryfied soliniod switch??????? Engel market what they call "12v in car battery charger" Has anybody had any expirience of these as they are only 2/3 the cost of the Arrid
FollowupID: 379171
Follow Up By: Jimbo - Monday, Aug 08, 2005 at 21:02
Ray,
Could you please put up your email address so that I, as one who is no longer a member, may contact you. Or send me a note: jimbest at internode dot on dot net.
I understand your black rig profile pic.
Jim.
FollowupID: 379264
Reply By: Member - Jeff M (WA) - Sunday, Aug 07, 2005 at 20:59
That device is excellent if you are going to spend a lot of time on the road away from 240v. It means you'll be able to fully charge you batteries on the road. Me, I just use a smart solinoid (like to redarc) and charge them off the 240v charge at home to get them up to full capacity.
AnswerID: 124219
Reply By: Redback - Monday, Aug 08, 2005 at 08:16
Ray the Arrid is specificly designed to charge a battery that is a long way away from your main starting battery (ie) second battery in caravan/campertrailer, also it does multipal batteries as well, they are a great unit very reliable easy to install and good value compared to the others, redarc/piranah/rotronics, after you install you forget it it does it all for you.
We put ours in the camper but they can be put in the vehicle too, alot of truck companies use them.
Baz.
AnswerID: 124240
Reply By: Member - Collyn R (WA) - Monday, Aug 08, 2005 at 11:11
Some well-meaning respondents are confusing the different functions of the Redarc relay and the Arrid Twin Charge Relay.
The Redarc 's purpose is to give the starter battery inititial charging priority. It close at around 13.6 or so volts before it parallels the second battery. It also opens if the starter battery drops below 12.5 volts.
The Arrid Twin Charge relay is a dc-to-dc converter. It is mounted close to the trailer battery and takes whatever (within reason) comes down the lead and converts it to 1.4 volts. It's purpose is to compensate for voltage drop on that supply lead. It does not give the starter battery any protection however, and a Redarc or similar unit is still needed for that purpose.
(The Arrid will assist to compensate for too thin cable, but cannot overcome problems such as corroded plugs and sockets etc).
Cannot really comment on prices except that $299 is the commonly advertised rate for the Arrid unit.
Trust this may help
Collyn Rivers
AnswerID: 124256
Follow Up By: Alloy c/t - Monday, Aug 08, 2005 at 12:35
Collyn , 1.4volts ,?????? surely you meant 14.1 ,, what would be the point of 1.4volts to recharge ????.
FollowupID: 379195
Follow Up By: Member - Collyn R (WA) - Monday, Aug 08, 2005 at 12:45
Sorry all (and thanks Alloy c/t.)
It's a typing error - should of course be 14.4 volts.
(My senior moments are on a much grander scale: went to introduce my son-in-law a time back - and simply could not remember his name.
Fortunatdly it turned out not to matter . My daughter left him a few months later - and has been trying to forget his name ever since!
Alloy c/t - would really like to learn more about your trailer.
Collyn Rivers
FollowupID: 379199
Follow Up By: Alloy c/t - Monday, Aug 08, 2005 at 13:40
Collyn, have member messaged.
FollowupID: 379206
Follow Up By: Mad Dog (Australia) - Monday, Aug 08, 2005 at 13:58
Collyn, are you sure that 14.4 volts is correct. The specs I read on the web stated 14.8
FollowupID: 379208
Follow Up By: Jimbo - Monday, Aug 08, 2005 at 21:01
Ray,
Jim.
FollowupID: 379262
Follow Up By: Mad Dog (Australia) - Monday, Aug 08, 2005 at 21:17
Sure Jim,
desertdust@yahoo.com.
yeah well the mother in law passed away yesterday so the black pic will be there a little while longer while I look after my two little girls until the missus returns from NZ. I have just about mastered the skill of putting hair into a ponytail...hahaha
FollowupID: 379268
Reply By: Member - Collyn R (WA) - Monday, Aug 08, 2005 at 18:56
Mad Dog
Not 100% sure. My info (of 14.4 volts) is from original Arrid literature but it's just possible they have increased recently the output.
I hope they have (i.e. that it IS 14.8 volts) as I have criticised the unit a few times in the past on the basis that 14.4 volts is not adequate to fully charge a conventional battery.
I'll talk to Arrid first thing tomorrow re this and report what I find on this thread.
Thanks for raising the issue.
Collyn Rivers
AnswerID: 124337
Follow Up By: Tim HJ61 (WA) - Monday, Aug 08, 2005 at 20:48
Collyn,
I'm interested in your theory regarding a 'normal' alternator not fully charging a normal vehicle battery - and accept it as correct.
I'm wondering however on the tolerances of equipment being powered at 14.8v or up to 15.5v with a three stage charge regulator on the alternator. Does it have a negative impact on them? I understand the positives of higher voltage on battery charging, but what about things such as lights that are rated at 12v and being pushed to near 15v by the charge system. Would they not have a shortened life with too much voltage?
I remember the days of 250v Perth power supply spiking over 260v and shortening the life of globes. I understand it's regulated now to 240v so better for our equipment. Wouldn't the same be the case for vehicle powered equipment - radio's, driving lights, inverters, fridges, etc etc etc.?
Tim
FollowupID: 379260
Reply By: Ray Bates - Monday, Aug 08, 2005 at 21:30
After reading all your coments I believe that I would be wasting my money in investing in a Arrid Twin Charge as I already have over 14volts at the terminals of my secondary battery and am only loosing about 1/2volt between my primary and secondary battery. My secondary battery is mounted on the drawbar of my caravan
AnswerID: 124364
Follow Up By: Member - Collyn R (WA) - Tuesday, Aug 09, 2005 at 09:31
Tim
You raise an interesting issue.
When I started to research material for 'Motorhome Electrics' I became concerned about this - not least because the TWC smart regulator in my OKA ran up to 15 volts (initially charging at 100 amps). This unit has also been used extensively in boats for over 20 years.
With one exception (low wattage halogen globes) there is however no record of electrical equipment being affected or damaged by this. In my case, the OKA's original headlight and other globes still work, as do all other equipment (including a laptop computer, printer etc).
Boat people too appear not to have problems via this despite their complex electronic equipment.
Do note that many three-stage mains chargers boost charge at up to 15 volts. Here again there are no reports of damage through overvoltage.
Giving both sides of the argument however, some US makers charge the battery at the higher voltage but use various techniques to limit the house voltage to 12.6 - 12.8 volts (but this may be for insurance reasons).
As noted, low wattage halogen globes are an exception. These are actually designed to run at 11.8 volts and the makers warn that their life will be substantially reduced if run at over 13.0 volts. This is also my experience.
I think this is an issue that is slowly receding. There is a clear move to AGM batteries and these charge quickly and close to 100% at voltages as low as 14.1 volts.
Collyn Rivers
FollowupID: 379325
Follow Up By: drivesafe - Tuesday, Aug 09, 2005 at 09:38
Hi Ray, did you have any form of load on the second battery when you took the measurement.
The best time to take a measurement is after you have spent the night somewhere and you are going to be doing about an hours driving.
Test the voltage at the front and rear battery after you start the vehicle and the after about an hours drive, take a measurement at both the front and rear batteries again and you will get an idea of the voltage drop occurring while charging the battery and by doing it an hour after starting off, you will also get an idea of weather the battery is charging quickly or not.
Cheers.
FollowupID: 379327
Follow Up By: brett - Tuesday, Aug 09, 2005 at 13:32
With these Arrids does the terminal voltage of the battery ever get to 15V? Even though the regulator is set to 15V during boost when this goes accross the battery terminals it will drop to whatever the battery is but a higher current will flow than if say 13.8 was put accross it, so therefore it will charge quicker as more current is flowing but as the battery charge level raises does the charger start to go intro float mode and drop to around 14.2V. As an example you cheap 4A batteyr charger can put out up to 17V as they are not regulated but oncew put accross a flat battery this quickly drops to the terminal voltage of the battery.
FollowupID: 379348
Reply By: Member - Collyn R (WA) - Tuesday, Aug 09, 2005 at 09:37
Ray
That 0.4 volt loss is vital!
Do not see it as 0.4 loss in (say) 14.4 volts - ie. a few per cent. Here's why:
Battery charge is a function of the difference between the battery voltage and the charging voltage - typically between 12.8 volts and (say) 14.4 volts. That's 1.6 volts - what you are thus losing is 0.4 of 1.6 volts - or about 25%. And that last 25% is vital (as 14.4 volts is not really high enough anyway).
Collyn Rivers
AnswerID: 124410
