Idle speed Patrol 2000 4.2TD
Submitted: Sunday, Aug 07, 2005 at 15:03
ThreadID: 25418 Views:5958 Replies:5 FollowUps:3
Idle seems fast - 800 RPM in neutral. What should it be and is the tacho in the dash a suitable guide, or are they not reliable enough to use as a guide? Have just had injector pump reconditioned and new radiator fan (rats!!! found huge cracks. Had to be a Nissan gen part, so wallet also has 'cracks'!) fitted. Picked up the Patrol Friday a'noon from new, recommended mechanic and noticed on the drive home that it seems to be idling faster than in past.
All previous services had been done by my old mechanic and I just got used to the old speed and sound. Ashamed to say that I did not note what RPM it was then - it just 'sounded' right.
Reply By: mick - Sunday, Aug 07, 2005 at 16:25
750rpm if this helps mines always been set at this
AnswerID: 124198
Reply By: Michael ( Moss Vale NSW) - Sunday, Aug 07, 2005 at 19:59
650rpm is about normal air con off!! Mine anyway 4.2tdi
AnswerID: 124212
Reply By: Member - Trevor R (QLD) - Sunday, Aug 07, 2005 at 21:13
Patrolee,
There is an idler screw which pretty much any mechanic should be able to adjust for you. When mine come out of modification stage up at Toowoomba it was also idleing fast but 2 seconds after the mechanic stuck his head under the bonnet it was all sorted. Mine idles at 750rpm no aircon, but you know your vehicle better than anyone and if you think it is idleing fast then it probably is.
Good to see you still using this site, I have been away working for a few weeks.
Now heading off for a week or so RnR.
Regards Trevor.
AnswerID: 124221
Follow Up By: Member - Collyn R (WA) - Monday, Aug 08, 2005 at 11:01
This thread worries me a bit!
I have a brand new 4.2 litre DX diesel Patrol (150 km on the clock). Twice when starting it idled at close to 2000 rpm - this on a 32 degree day in Broome.
Restarting fixed the problem - each time on the third go.
Anyone have any ideas.
Collyn Rivers
FollowupID: 379178
Follow Up By: Patrolee - Monday, Aug 08, 2005 at 20:34
Cheers, Trevor R, I AM back. This site is top of my favourites list - lots of helpful people and interesting topics. Since you have been away, I have found new and more helpful mechanic who has fixed leaky injector pump (at much less than the $6000 quoted by dealer!) and found cracks in radiator fan in the process. Fan has been replaced too. Did you catch up with old thread - I got my $375 back from dealer.
Have spoken to new mechanic about overheating probs and he has pointed out two changes we could make to improve situation - relocate licence plate and big spotties - all of which are restricting, so some extent, the flow of air the radiator. He moved plate, to under driver's headlights to test effect. We talked about the spotties - he thought/hoped I could live without spotties - I know I cannot! When towing horsefloat, I want as much notice as possible about what is in front and at side of road - horses hate rough stops!! Owner hates vet bills! I'll look at smaller dimension spotties that still throw enough light to do the job. If that does not work, I'll have to start saving for the conversion you mention.
Enjoy your RnR. Cheers from Patrolee.
FollowupID: 379257
Follow Up By: Member - Trevor R (QLD) - Tuesday, Aug 09, 2005 at 10:40
Firstly Collyn,
With that many k's on it I would think it only something small that the dealer should address in no time. The pre-delivery fee you pay when you buy new should pick up on things like this, it really ticks me off but I have had similar niggly problems on a couple of the newies I have brought.
Last but not least Patrolee,
I have followed a few of your threads with interest, as we have been experiencing similar probs to you. The airflow track you seem to be going down has been travelled by myself and many other 4.2 owners to no benefit. (not saying it won't work for you though) I have now got 240mm lightforce lights on the front of mine blocking almost all of the available space for airflow and am not having any drama's with heat anymore. When I was having heat probs I had the IPF 800's as driving lights and they are much smaller than my new lights, therefore airflow to radiator was not the problem in my instance. Remember new Nissan's come with the b/bar lights and t/bar standard now, so if Nissan thought this was the problem surely they would stop supplying newies with s/lights.
Just my thoughts, hope this helps.
Regards Trevor.
FollowupID: 379330
Reply By: JamieMac - Monday, Aug 08, 2005 at 15:33
Its a personal thing. I have my idle set as low as possible at the pump and then use the hand throttle to set about 6-700 depending on whether engine is hot or cold. That way I can drop the hand throttle off at the top of big hills to slow my descent using the engine as much as possible.
Another trick is to pull the aircon idle controller wire off so that the compressor slows the engine even more in really steep country. You'll know you need this as you will still be sweating regardless of the ouside temp!! If you leave the wire on the fast idle actuator will simply increase the revs and away you go.
If you want to set 1000 at idle to help you get off a standing start then do so. But I recommend using the hand throttle for all settings above absolute min idle.
JamieMac
AnswerID: 124295
Reply By: Member -Dodger - Monday, Aug 08, 2005 at 17:50
Factory set is 800rpm'
Mine has always idled at 750 after warm up so I don't worry.
Collyn you may have some trouble check with the dealers mech not the dealer as I think your model is intercooled mine is not.
Cheers Dodg.
AnswerID: 124320
