HZJ 75 Engine 1hz engine coolant drain plug
Submitted: Monday, Aug 08, 2005 at 12:00
PeterDarwin
Where, oh where is it hahaha
I changed my coolant on the weekend, with the good toyota red stuff.
I must be stupid, I could not find the engine drain plug so I just used the radiator drain plug and took the bottom hose off, then took out the glow plug temp sensor, I think all of that did the job.
But I am still curoius because in my gregories manula it shows an engine drain plug I can fin the same location but no plug, the manual have a photo of an 80 series but it should be the same??
Reply By: Wayne (NSW) - Monday, Aug 08, 2005 at 12:20
Peter,
When ever I have had to drain the coolant I have always used the radiator drain plug, I did not know there was on the engine.
Wayne
124265
Reply By: 120scruiser - Monday, Aug 08, 2005 at 12:50
Passengers side right near the oil pressure sensor.
You will probably have to remove the oil filter to see it.
Definetely there as I have to position the oil feed to the turbo carefully to miss the drain plug when doing conversions.
124267
Reply By: PhilRob - Monday, Aug 08, 2005 at 21:36
Plug is on left side directly behind the injector pump, you can get a 14mm socket
in there with an extension, shouldn't have to remove the oil filter, you'll be
surprised how much coolant comes out once the plug is removed even after you've drained the system via the radiator drain, tighten the plug to 18 ft-lb when you put it back in.
124366
Reply By: Billowaggi - Monday, Aug 08, 2005 at 22:32
Hi Peter , this may not apply to you, but may help others .from 1998 the engine drain plug is deleted! The cast boss is still there in the engine block but has not been drilled and tapped.This applies to 100 series as
Regards Ken.
124374
Follow Up By: PeterDarwin - Tuesday, Aug 09, 2005 at 09:31
I am not blind then hahahahah
I do have a 1998 model so I was looking for something that is not there.
I did not think I could miss it .
Wonder why they deleated it?? who knows
379326
