New Wheel Carrier
Submitted: Monday, Aug 08, 2005 at 14:52
Wayne (NSW)
Taken a bit longer to get the photos but they are ready to go now.
!MPG:8!
!MPG:9!
!MPG:10!
!MPG:4!
!MPG:5!
!MPG:7!
I think the photos show how the rear bar/ wheel carrier works.
My main concern was the carrier itself. I did not want it to break on rough roads so the side braces on the main up right were added and a brace under the top bracket.
The steel tube is 50mm x 100mm and the rear bar is 5mm steel plate. A piece of checker plate will be added soon and that will be on top of the bar to give a bit of grip when I stand on the bar.
I am very happy with the way it turned out.
Wayne
Reply By: Capt. Wrongway - Monday, Aug 08, 2005 at 15:17
G'Day Wayne,
That is one set of "serious" brackets! If all your welds hold, they should say put! Mind you , if they do come adrift, I do'nt want to be behind you. ( just kidding )
Nice work.
Regards,
Bazza.
124288
Reply By: Alloy c/t - Monday, Aug 08, 2005 at 17:13
Looks good ,also looks like it weighs a "ton" , you in need of new springs and shocks ?? LOL
124312
Follow Up By: Wayne (NSW) - Monday, Aug 08, 2005 at 21:07
Yes there is a bit of weight there but the Troopie can take it. I can stand on the back of the vehicle and the vehicle does not dip down. The 12 leaf rear
suspension has a lot to do with that.
Wayne
379266
Reply By: Member - 'Lucy' - Monday, Aug 08, 2005 at 23:26
I reckon K-MAR would be seriously impressed with your effort
124385
