In car compressor.
Submitted: Monday, Aug 08, 2005 at 18:32
ThreadID: 25442 Views:4387 Replies:4 FollowUps:5
I have just purchased a Bluetongue iv air compressor to fit in the vehicle. I would of thought that drawing approx. 18 amps it would have to be wired through a relay. I have been advised not to do this because it can give some running problems. Advised to use heavy duty 25 amp switch. How have other forumites hard wired their compressors.
Thanks,
Ron.
Reply By: Member - Phil G (SA) - Monday, Aug 08, 2005 at 19:33
I run mine thru a 30amp switch (Jaycar) for 4 years now. The switch has worked fine, and its been used heaps.
But I had a blade fuse in a holder back at the battery, which must have corroded, then melted, so I have now soldered a 30amp blade fuse into the wire instead, so theres no way corrosion can happen. Also you'll need at least 8Ga wire, and a good earth.
phil
AnswerID: 124345
Reply By: Member - Jeff M (WA) - Monday, Aug 08, 2005 at 21:16
Can't understand why there would be problems with a relay?
I've been running my Bluetounge IV for over 12 months now through a pressure activated headlight relay with no problems. It runs every day to charge my air tank.
AnswerID: 124362
Reply By: Wayne (NSW) - Monday, Aug 08, 2005 at 21:33
Ron,
It will not hurt to run the compressor through a relay, but don't make the big mistake of fitting the compressor under the bonnet.
3 things that a compressor does not like,
heat
dust
water
All the good compressors have a thermal cut off switch. When the compressor gets to a certain temperature they will turn them selfs off rather burning out. If the compressor is mounted under the bonnet it will get very hot under there and the compressor will turn off.
I have mine fitted at the base of the cargo barrier so that the compressor is cool in the vehicle out of the dust and water. With the hose that comes with the compressor I can pump up the front and rear tyres as well the tyre on a trailer with out having to unhitch the trailer.
Wayne
AnswerID: 124365
Follow Up By: Ron - Monday, Aug 08, 2005 at 23:32
Exactly why I am going to install it in the inside rear quarter cavity where the jack sits in my 62 series. Especially because of the heat situation under the bonnet. Also, the bluetongue is fan cooled which is one of the reasons I went for it. As you say, heat kills electric motors. I think I'll ignore the negativecomments I've been given and wire it through a relay.
FollowupID: 379294
Follow Up By: Member - Davoe (Widgiemooltha) - Tuesday, Aug 09, 2005 at 06:40
In 100s I have seen them fitted between the door and the seat. So if you open the rear door it is bolted directly under the seat, surprisingly very much out of the way of everything
FollowupID: 379300
Follow Up By: Member - Jeff M (WA) - Tuesday, Aug 09, 2005 at 12:38
Mines quite happy under the bonnet, it's never cut out either, even after doing 4 vehicles non-stop in a row. (16 tyes!).
The blue tounges have a fan cooled motor.
Mine runs while we are driving if using the horns, and personally I don't care for the rattle in the cab while the kids and missus are sitting in there while I'm pumping tyres up, under the seat in a hilux is out of the question anyway, you can barley get your hand under there! Nup, I'm happy with it under the bonnet, and Opposite Lock sell brackets for Under Bonnet mounting, and Thomas build these pumps for air suspension kit's specifically to go under the bonnet, so I don't see the problem. I've hosed it down with the high pressure cleaner and degreaser so many times I've lost count and it's never missed a beat.
It's got a washable air filter on it's intake and it's electronics are sealed, the only thing exposed is the coils for the motor, just like your alternator... Besides mounted where it is, it doesn't see much mud anyway as it's tucked in behind the airbox up high on the wheel arche.
!MPG:13!
FollowupID: 379340
Follow Up By: V8troopie - Tuesday, Aug 09, 2005 at 15:45
I would second the under bonnet installation. Who in their right mind would want the racket of the compressor coming on and off at random ( powering ARB diff locker) inside the cabin?
Electric motors and heat, well, mounting it right above the exhaust manifold is perhaps not a good idea but up front, behind the head light, it runs cool enough.
There is not too much dust there either, unless driving in convoy too close up.
Water ingress? I'd just switch it off during a crossing, there is enough reserve air pressure in my in bull bar air tank to keep the locker happy. Besides, I would chicken out anyway if the water depth was over the top of the wheels ;-)
Klaus
FollowupID: 379358
Reply By: Member - toohey - Tuesday, Aug 09, 2005 at 06:50
gid'ay ron
i've got a bushranger maxi,i store it in the carry bag can take it any where i want,to another vehicle etc.just a thought.
regards toohey.
AnswerID: 124395
Follow Up By: Member - John C (QLD) - Tuesday, Aug 09, 2005 at 07:52
Have a blue tongue MK 1, mounted under the drivers seat and powered via a relay. Been there for over 12 years. Only use it to pump up tyres when I am not driving :-)
FollowupID: 379305
