snow skis
Submitted: Tuesday, Aug 09, 2005 at 23:52
ThreadID: 25483 Views:1759 Replies:7 FollowUps:3
Totally off topic and I apologise but in my sheltered life had no-one else to ask.
Have owned my own ski boots since forever but always hired my snow skis and had them adjust and fit them to my boots. About to pick up a set of skis I purchased on e-bay for an upcoming ski trip and have no idea how to fit them to my boots.
Any help would be appreciated.
Sorry not directly 4wd......they do play in the snow though....
Trevor
Reply By: Well 55 - Wednesday, Aug 10, 2005 at 07:24
G'day Trevor. It all depends on what type of bindings that are on the skis.
The way to do it would be to place the boot on the ski with the toe in position. Look at the rear part of the binding and you will see where to move it either forward or back to hold the boot in place.
You then need to adjust the break-away release at the rear of the binding, so if in a fall the boot will "break" out of the binding. Make sure the ankle straps are fitted to the ski.
AnswerID: 124551
Reply By: snowman - Wednesday, Aug 10, 2005 at 08:44
Hi Trevor
Do yourself a BIG Favour and take them to a ski shop and have them adjust them for you. If you dont know anything about adjusting bindings it would be a mistake to do it yourself. The ski's might need to be waxed and the edges done also.
It would be a pity to wreck your holiday because you have injured yourself due to your ski's not coming off when you fall.
Cheers Dave
AnswerID: 124566
Follow Up By: Member - Chrispy (NSW) - Wednesday, Aug 10, 2005 at 18:40
Absolutely agreed. I've seen more ankle and leg trauma on the snow after self-adjusted bindings have been used. It's a bit of a science - your weight, your build, your strength, your height and your EXPERIENCE go into the equation. If you're a biginner Trevor, you'll want them adjusted on the "loose" (relatively easily triggered) side for safety's sake.....
Take 'em to the shop.
FollowupID: 379541
Reply By: Member - Tonester (VIC) - Wednesday, Aug 10, 2005 at 09:07
Though its easy to do, I agree with snowman, you can break something serious if the bindings are not set correctly for your weight and skiing talent. Esp if your not sure about it.
AnswerID: 124569
Reply By: Member - Toonfish - Wednesday, Aug 10, 2005 at 16:33
like the other too it is easy to do but really you should get a ski shop or experienced person to do it foryou as weight ability and type of skier really count for instance if they are set too hard you may not break free and nreak a bone (worst case scenario!)
but also your toe and heel mounts on the boots also wear out after awhile and may hinder bindings (they make release too easy.)
took me awhile and being shown by proper ski repaired/fitters .
love to update my skiis (salamon x9 199cm) bloody long and fast need to downgrade to a less extreme old bugger maybe bandits.
hope this helps
AnswerID: 124635
Reply By: Casnat - Wednesday, Aug 10, 2005 at 18:30
thanks for the responses everyone. Overwhelming advice to get the experts to do it cannot be ignored.
Trev
AnswerID: 124655
Reply By: Ted (Cairns) - Wednesday, Aug 10, 2005 at 20:07
Hi Trev
Definitely if you're not experienced get someone who KNOWS HOW to adjust them. And get them to adjust them TIGHT. That is, you can still get your foot out of the binding by yourself (by twisting it sideways), BUT with significant effort.
Why? Coz quite a few accidents I saw resulted after so-called experts adjusted bindings to release at the slightest of forces. The result? After loosing one's skis several times for no reason people start adjusting them themselves, right there on the slopes. And guess what - they set them really tight. Next thing they have an injury...
Happy skiing!
Ted
AnswerID: 124677
Follow Up By: Member - Chrispy (NSW) - Wednesday, Aug 10, 2005 at 20:21
Agreed - but "loose" is a relative term. I used to run 210's on GS courses around the world, and my bindings were set ultra-tight so they would not release on chattering ice. I would not advise that a beginner had their bindings as tight as mine..... but then again they wouldn't be on 210's and they wouldn't be doing the speed.
FollowupID: 379560
Follow Up By: geocacher (djcache) - Thursday, Aug 11, 2005 at 05:41
Maybe firm is a better term.
But if DIN settings adjusted to weight and ability are used you can't go far wrong. After all thats what the binding engineer put those little numbers on there for in the first place.
Back when I was working in ski hires it was fairly subjective. Get client to boot up and do a kick & twist and adjust for a firm setting that allowed release.
I notice these days most do it by the DIN chart. I dare say its for two reasons. One if the lawyers get involved there's a science to it, and two if the lawyers get involved and the setting had been changed you know what it was I suppose, that way if someone has altered it it's their problem. Not that they'd get checked going back into the racks on return so maybe more of the just in case than anything else.
FollowupID: 379608
Reply By: geocacher (djcache) - Thursday, Aug 11, 2005 at 05:52
Another afterthought that is on topic. It never ceases to amaze me how many people I see carting skis on their roof without protection.
Bindings are not simple devices and their correct function is essential in preventing injury. Yet people stick them on the roof and subject them to hundreds of km of insects, stones and other nasties (why do windscreens get sandblasted?) and then expect them to function perfectly to save their tib/fibs and ACL's. And then if they own their own skis 99.9% don't do a release test when they go and use them. Many don't do so even do one once a season.
Worse still, they put them up their tips forward to catch the wind and slap together and vibrate buggering the surface and edges at the tips.
Put them in bags people. And skis in bags can still go in many lockable roof racks. (Don't buy the ones where both skis sit flat side by side.)
It's snowing and I'm going....
AnswerID: 124730
