rollers on roof racks
Submitted: Wednesday, Aug 10, 2005 at 10:43
ThreadID: 25493 Views:2191 Replies:5 FollowUps:2
Hello out there
The father in law has a set-up for his kayak which consists of three roof bars with the front two having the kayak cradles and the rear one has a roller on it (a section of pipe with bearings on the inside). I know he had this custom made. He uses this to lay one end of the kayak on then just roll it forward onto the cradles. Does anyone know of roof rack manufacturers that supply a bar like this or is custom the only answer?
Thanks, Brian
Reply By: ellmcg - Wednesday, Aug 10, 2005 at 12:31
I just typed 'kayak roof racks' into Google. There seems to be no shortage of suppliers, including major manufacturers like Thule.
AnswerID: 124596
Follow Up By: bware - Wednesday, Aug 10, 2005 at 13:38
Yeah, I've checked lots of websites. It's the rear bar with a roller that I'm interested in and can't find any info on. I know that there are side loaders for boats/canoes but these are expensive. A roller on the rear bar seems a cheap and easy idea/design yet it may be a case of a non-mass produced item which will need to be custom made
FollowupID: 379505
Reply By: Ian - Wednesday, Aug 10, 2005 at 19:17
I had the same issue with a Kayak. Go to any supplier that sells Rhino Racks. They have all the gear necessary as standard of the shelf product.
CHeers
Yarn
AnswerID: 124665
Reply By: tessa_51 - Thursday, Aug 11, 2005 at 08:13
bware
Sounds like a great idea - I have a problem lifting my kayaks on to the cradles on the roof of my lifted 4by. You've got me thinking about adapting the roller stand that came with my little fold-up work bench from Bunnings for $24.99. It's designed to rest the other end of whatever you are working on. Its a chrome roller, about 40cm wide and about 50mm diameter. If I could attach it in some way to a third roof rack at the rear it would do exactly what you are talking about. Have a look at them.
tessa
AnswerID: 124736
Reply By: Steve - Thursday, Aug 11, 2005 at 08:38
I use either a kayak stacker (if I'm carrying more than 2) or Rhino Sportz (cradle type) Carriers. A couple of blokes I know use those tradesman's roller racks. I think they're used to load ladders. Seen plenty of them around and keep thinking "must get a pair of those sometime" but still haven't. Can't be diffficult to find.
AnswerID: 124741
Reply By: Member - Duncs - Thursday, Aug 11, 2005 at 10:38
I have a commercial roof rack with a roller accross the full width at hte back.
Came off an old Telstra van. Find the wrecker who has the vans and you could well find the roof rack.
Duncs
AnswerID: 124751
Follow Up By: bware - Friday, Aug 12, 2005 at 02:28
All good info to go on,
FollowupID: 379735
