Landcruiser split rims on Pajero
Submitted: Monday, Aug 15, 2005 at 10:52
ThreadID: 25612 Views:6667 Replies:5 FollowUps:4
Hello all,
I have just stumbled accross this site, Wow.... what a find!
I have a 1997 NK 2.8 Diesel Pajero, which I have been using for mixed work for the last 4 yrs. It has 15" steel rims, and I have tried a few different types of tyres to suit my needs which is genuine 60/40 off/on road use.
At present I have Cooper ST 30x9.5 LT tyres, which are almost done, at 88,000kms. They have been OK, but I want to go with Landcruiser 16" split rims, and BFG AT's this time. My brother told me that cruiser rims will fit suds and hubs on my Pajero, and there is enough clearance by looking at wheel well, although I am not 100% sure. I am told that both Mitsu and LC split rims have -3mm offset, so that part looks covered.
Can anyone see any problems with me doing this? Odometer change does not concern me too much.
Thank you all very much. :)
Steve
Reply By: Member - Roachie (SA) - Monday, Aug 15, 2005 at 11:28
Best way would be to borrow a set if you can and try them on. Mainly need to watch out for the front wheels hitting on steering components under full lock and also possibly clearance problems under the wheel arches.
However, I would question your desire to fit splits in the first place.
Member- Willem was going to try to get a set of splits for his GQ when he bought it some short time ago. We ended up "convincing" him that he'd be better of with the mag wheels that he already had....I think he is happy with the cloice he ended up making.
Good luck
Roachie
AnswerID: 125245
Follow Up By: davros_who - Monday, Aug 15, 2005 at 13:18
Thanks for the reply Roachie.
I just did a site search and could't find that post.
How did you convince him?
I presently only have 15" rims, and cannot find a tyre of decent cabability that has the required load and speed ratings. The Coopers that I will be replacing, are not legal as far as my insurance Co. is concerned, so I wanted to go with bfg LT235/75 16" which have a load rating that exceeds the 105 that I need. I also need speed rating of "S" which this tyre has as well, so having to obviously get 16" rims, I thought I would go with the split rims, and be consistant with what I have on my tailer.
Thanks again. :)
Steve
FollowupID: 379981
Follow Up By: Member - Roachie (SA) - Monday, Aug 15, 2005 at 14:13
Steve,
I'm certainly no tyre guru; but I'm surprises that you can't find a suitable 15" tyre to meet your requirements. Until recently....well maybe up to about 10 years ago.... (and maybe even now) 15" was THE most popular size wheel and you could get just about any type of tyre you wanted. Then the manufacturers (of vehicles) started making them with 16" wheels and there used to be very limited option of what replacement tyres you could buy. More recently again, we are seeing the same issue with 17" wheels on the 120 Prado etc.
If you definitely can't find the right tyre in 15" wheel size, I'd be inclined to suggest you look at 16" wheels (either one piece steel or alloy etc). These should certainly fit your pajero as long as the offset is okay.
I changed my Nissan 16" wheels over to ROH Sunraysia style white steelies (IMHO the Nissan wheels are krap cos they collect dust/mud in the inner recess and that throws them out of balance). The added bonus with the new wheels was that they came with an extra 20mm of off-set, which increased my track by 40mm and gave me a bit of extra clearance on the rear inner guard...which is handy cos I've removed the sway bars for added articulation, but that would've otherwise meant I'd be srubbing the back tyres.
If you DO change wheels to 16", be aware that tyres in that size are generally more $$$ and also even the white/common ROH sunraysias were about double the cost of 15" ones. If I could've been sure that 15" wheels would have fitted, I'd have bought that size rather than 16" wheels (much cheaper wheels and tyres as far as i am aware).
Roachie
FollowupID: 379993
Reply By: Member - John C (QLD) - Tuesday, Aug 16, 2005 at 16:10
I run nissan 16x6 rims on my 96 pajero.
Same offset, pcd on the studs and the centre hole is only 1mm larger.
Not sure if the centre hole is the same on the LC rims, and offset is definetely different.
They are the white rims off the older RV patrol. Got a set of 6 for $20.00 each.
Problem is catching them at the wreckers before they through them out.
AnswerID: 125420
Reply By: angler - Tuesday, Aug 16, 2005 at 21:03
Don't you just wish there was someone in the Australian standards department with at least half a brain. Then all 16" would have six studs would fit all trucks with 16" wheels. All 15' would be the same. etc etc.
If they didn't comply then they don't get into the country.
Wouldn't that be great, sort of like it was back in the year dot when there was only very early model 4WD's.
Did you know that the three cylinder Suzuki 4WD wheels fitted a rolls royce. True story....
AnswerID: 125472
Follow Up By: Member - Davoe (Widgiemooltha) - Wednesday, Aug 17, 2005 at 20:35
and take the same oil and air filters etc.......... angler 4 PM
FollowupID: 380331
Reply By: muzzgit (WA) - Wednesday, Aug 17, 2005 at 00:45
Even if you DO go for the split rims, you can get better, stronger, cheaper tyres to fit those rims than BFG AT's.
I'm not bagging BFG tyres, I have them on my Patrol, had them on my FJ62, had them on my Navara, and had them on my FJ45.
But when it comes to 16" splits, there's heaps to choose from.
But another question....Aren't BFG AT's in 15" up-to-spec with the speed and load rating you need???????
AnswerID: 125502
Follow Up By: davros_who - Thursday, Aug 18, 2005 at 15:22
Hello again all,
Thanks for the replies,
I have tried a few brands of tyres, and quite a few people have told me to go with the BFG AT's this time as "they are the best".
I know that everyone has their own opinion on tyres, but...... If the BFG's aren't the best for my uses, then what would be? I do between 50 and 70000kms per anum. A lot of that is gravel, some mud....Though not much of that about lately, and about 25 to 30000kms sealed road. I am not fussed about road noise, I just want a strong tyre that will last, with proper care, and a tyre that has a 1/2 decent tread pattern to grip off road when I need it to. I do a lot of towing with a very heavy duty 7x4 trailer, and load the vehicle up for longish trips with up to 6 people and two dogs.
BFG's have a max load rating of 104 in 15", (for the original 15" x 6" rims that I have) and that same tyre is speed rated R. I need minimum 105-S to satisfy insurance company. I can get around the speed rating by fitting a new tyre placard with appropriate speed limitations for vehicle, and a letter to notify Ins Co, but the load rating of 105 is essential.... So I am told.
I have noted advice above regarding split rims, and have done some other research of my own. I have decided to go with a decent (non split)16 x 6.5" or 7" steel rim when I change tyres next month.
Thanks again for all of the good advice.
Steve :)
FollowupID: 380459
Reply By: davros_who - Friday, Aug 19, 2005 at 11:15
Hello again all, (Sorry all, I'm just learning to drive this board thing)
Steve :)
AnswerID: 125896
