ARB portable air compressor
Submitted: Monday, Aug 29, 2005 at 12:11
Capt. Wrongway
G'Day all,
I was using my compressor the other day to pump up a trailer tyre and noticed that the hose fitting ( to connect to the tyre valve ) was leaking air. I had'nt noticed this before, although I may have been doing this for a while, as I hav'nt had the need to use the compressor for some time. I ashume that it should'nt leak, as the air
tank on the compressor would never fill or reach "shut off" presure. Am I correct? If so, does any know where I could pick up a new small fitting that would have a presure guage attached. It would need to be smaller that a service station type as it needs to fit in the carrying box along with the compressor.
Any ideas.
Regards,
Bazza.
Reply By: Member - Chrispy (NSW) - Monday, Aug 29, 2005 at 13:06
First thing I do with my compressors is immediately replace all of the silly clamps they use with some proper stainless steel screw-on hose clamps. If you bought the compressor new, then you probably would have had the decent VDO gauge that came with it..... a much better option in my book than one attached to the compressor. Reason is that when airing down at the beginning of a day out, you don't have to drag the entire compressor box out just to know that you're down to your desired pressure.
127295
Reply By: Member - Gary W (VIC) - Monday, Aug 29, 2005 at 13:11
Capt.
My understanding of the ARB Compressors is that unless it has been installed for use with air lockers they don't come with pressure cut off switches. I had to buy one in the case when my air locker unit failed and it definately did not have a cut off switch.
For this reason the tyre valve fitting does not shut the air off when you remove it from the tyre and I wouldn't fit one that does unless you get a cut off switch. ARB have the switches. As for the tyre inflator and gauge I got
mine from the ARB dealer who installed all my gear.
Gaz
127296
Follow Up By: Member - Chrispy (NSW) - Monday, Aug 29, 2005 at 13:26
My original compressor was insalled by ARB under my driver's
seat as a compressor-only. It was not installed to drive lockers. The pressure switch came with it as part of the loom...... not as an extra.
381810
Follow Up By: Member - Gary W (VIC) - Monday, Aug 29, 2005 at 13:49
Fair enough - Still think Capt. should check otherwise something will go bang if you put a gauge/inflator on. G
381812
Reply By: Moggs - Monday, Aug 29, 2005 at 13:55
You can get the ARB compressor in 2 models in the carry case - 1 with the pressure cut out switch and 1 without.
I would suggest that if yours is leaking from the tyre valve connection then you have the model without the pressure switch.
I have an ARB compressor without the pressure switch and it does leak as described above. Also, have not changed any clamps and all are still good.
127304
Reply By: Capt. Wrongway - Monday, Aug 29, 2005 at 14:04
Thanks Guys,
Good point Gary. I checked and my unit ( RDCP ) does come with a presure switch and portable VDO guage. I think I'll take Chrispy's advice and replace the fitting and clamps with some thing better. I also take Chrispy's point on having a portable gauge. Good thinking.
Thanks all.
Regards,
Capt.
127305
Reply By: 120scruiser - Monday, Aug 29, 2005 at 14:49
capt. wrongway
Just check that the end isn't loose.
I think
mine is just a screw on fitting but I could be wrong.
Worth a try.
I used
mine on Sunday at
Stockton but I didn't take any notice.
120scruiser
127310
Follow Up By: vitara - Monday, Aug 29, 2005 at 15:08
Hi there 120scruiser, I take it you live locally to
stockton beach, next time you go let me know and if you don't mind I"ll make arrangements so my wife and I can meet you there. Would like to meet some of the people that are on this
forum. I like to put faces to names where I can. Take Care Vitara.
Ps Thats if you interested. No offence if you prefer a day out with the family alone. I presume your talking about
stockton beach NSW/ Anna Bay
381819
Follow Up By: 120scruiser - Monday, Aug 29, 2005 at 17:25
Yes thats the
stockton beach I am talking about.
Not local,
Sydney boy but my parents live on the central coast so I am up there a fair bit.
I will probably not be going up there for awhile as I only wanted to take the new car for a run on the sand before I go on my desert trip in three weeks. I had to make sure it went into low range ok.
You can email me at lonards at bigpond dot net dot au as we do get around a fair bit up at the watagans and blue mountains.
Would love to meet up.
Catch ya
120scruiser
381838
Follow Up By: vitara - Tuesday, Aug 30, 2005 at 15:21
Hi there 120scruiser, I'm actually from glenmore
park (penrith) area, we go up the coast a fair bit as my mum and sister live at Marti (I think spelt write) could be Mardi new area anyway just near Tuggarah. My mum use to live at buff point but then the old man passed away so she sold and bought a place at Mardi ?. We often go up around
lithgow to the nunes
state forest some good tracks up there. Any way have a safe trip hope the 4wd does it job for you. Take Care Vitara/ Steve M
381946
