80 series NA diesel oil leak
Submitted: Monday, Sep 05, 2005 at 15:28
ThreadID: 26147 Views:2042 Replies:2 FollowUps:4
I am looking to see if this has happened to anyone else, after a weekend out bush with some small water crossings I developed an oil leak, it looks as though it is coming from the front crankshaft seal as it is being flicked all around the engine bay. Though it could just be from thermal shock so took it for a drive around the streets and by the time I got back it was bleep out.
Has anyone had a similar problem? when I called the local 4wd mechanic for a quote he was suprised as he had not heard of it happening, especially with only 170k on the clock.
Reply By: Truckster (Vic) - Monday, Sep 05, 2005 at 17:03
www.lcool.org technical section would be a good place to start
AnswerID: 128393
Follow Up By: Wally80 - Monday, Sep 05, 2005 at 17:49
it was, but there was nothing there
FollowupID: 383035
Follow Up By: Truckster (Vic) - Tuesday, Sep 06, 2005 at 09:26
Have you posted the question up on the 80s list?
FollowupID: 383172
Reply By: Member - Davoe (Widgiemooltha) - Monday, Sep 05, 2005 at 18:07
been under enough of them. transfer cases, rear diff pinion seals front axle seals yea but not much in the way off engine oil leaks. Still just coz it isnt common doesnt mean it cant happen
AnswerID: 128410
Follow Up By: Member - Davoe (Widgiemooltha) - Monday, Sep 05, 2005 at 18:09
It isnt power steering fluid is it? that would also come from the front
FollowupID: 383039
Follow Up By: Wally80 - Monday, Sep 05, 2005 at 18:33
I don't thinks so, mainly from the sheer volume and colour of the oil, the steering still sounds fine as well
FollowupID: 383047
