tyre rotation
Submitted: Monday, Sep 05, 2005 at 19:46
ThreadID: 26161 Views:2310 Replies:8 FollowUps:8
Hi, Quick question, tyres should be rotated but what kind of klm's between rotation?Thanks in advance
Reply By: Member - John C (QLD) - Monday, Sep 05, 2005 at 19:58
Every one will have a different idea. Some don't at all.
But every 10,000k is OK. I remember to do it every time I change the oil filter.
AnswerID: 128444
Follow Up By: chel - Monday, Sep 05, 2005 at 20:02
thanks, we didn't always remember with old GQ and back tyres didn't last as well. New vehicle so want to do the "right thing". Cheers
FollowupID: 383079
Reply By: Member -Dodger - Monday, Sep 05, 2005 at 20:52
I rotate mine every 10grand.
Easy to remember when doing a full service.
Cheers Dodg.
AnswerID: 128457
Follow Up By: chel - Tuesday, Sep 06, 2005 at 05:09
Thanksyou for answereing question, 10000 seems to be the best time.Cheers
FollowupID: 383154
Reply By: Member -Dodger - Monday, Sep 05, 2005 at 20:54
Easy to remember at major service.
Cheers Dodg.
AnswerID: 128459
Follow Up By: chel - Tuesday, Sep 06, 2005 at 11:45
Hi Dodger, thankyou for reply I think will go with the 10000. cheers.
FollowupID: 383198
Reply By: Diamond (Vic) - Monday, Sep 05, 2005 at 22:12
usually every ten.
but i have a good look at them every 5 and if theres any unusual wear ill rotate them.
AnswerID: 128496
Follow Up By: chel - Tuesday, Sep 06, 2005 at 05:11
Thanks Diamond, appreciate the response, husband and i were debating between 5000 and 10000klm. Cheers
FollowupID: 383155
Reply By: muzzgit (WA) - Tuesday, Sep 06, 2005 at 01:15
Having 5 of the same tyres I rotate all 5 every 10,000 but was talking to a suspension guru the other day who said the best way to stop right pull in a GU Patrol is to keep the tyre with the most tread on the front left. He recons the best thing is only rotate 4 tyres for 40,000 then put the spare on front left.
Food for thought for GU owners. Dunno if it works?
AnswerID: 128525
Follow Up By: chel - Tuesday, Sep 06, 2005 at 05:08
thanks for response was going to do every 5000 but 10000 seems to be the go with checks in between. Haven't heard of the right pull in GU, the GQ had nasty left pull but after some work done and a few dollars that was fixed. Cheers
FollowupID: 383153
Reply By: G-wizz - Tuesday, Sep 06, 2005 at 08:14
Front tyres wear out faster than rear tyres so rotating all 5 tyres will shorten the life of all your tyres. I don't rotate tyres front to back and replace them in pairs as required. This gives maximum life of the rear tyres and hence reduces cost.
AnswerID: 128536
Follow Up By: chel - Tuesday, Sep 06, 2005 at 11:43
Hi G-wizz, thanks for info, I have only had the problem with back tyres wearing faster, this was on a GQ. Appreciate the help Cheers.
FollowupID: 383197
Reply By: chump_boy - Tuesday, Sep 06, 2005 at 08:33
I spose it depends on wether you are happy with your tyres or not. If you are happy, rotate 4 every 10k. If not real happy, rotate all 5 (or 6), then when replacement time comes, you can replace all of them.
Also, depends on how long you plan to keep the car, and what the money situation is like. Can you afford to fork out $1500 on a full set of tyres, or would you rather break it up a bit, and only buy 2 at a time?
In the long run, it doesn't make a real lot of difference. In a 3 year lease, it could be the difference between paying for tyres, or not paying for any at all!
Chump
AnswerID: 128538
Follow Up By: chel - Tuesday, Sep 06, 2005 at 11:48
Hi Chump, Thanks for help, were lucky to get tyres to last 12-18 ths little own 3 years.We do about 60% dirt driving because of where we live ,just don't seem to hold up. Much appreciate the help, Cheers Michele
FollowupID: 383200
Reply By: Mainey (WA) - Tuesday, Sep 06, 2005 at 10:44
chel,
Swap the front Right with the back Left, and the front Left with the back Right.....
as to when you do this depends on the tyre use and driving conditions, as 1,000 klms on the stony, corrugated, dirt tracks up north is like 12 months driving in Toorak.
AnswerID: 128567
Follow Up By: chel - Tuesday, Sep 06, 2005 at 11:40
Hi Mainey, thanks for advice and will take on board, I hadn't thought to swap right to left, front to back only thought on front to back. I agree with the dirt and toorak. Cheers
FollowupID: 383196
