Prado 120 TX3400 Electrophone UHF CB Radio
Submitted: Monday, Sep 05, 2005 at 21:21
ThreadID: 26166 Views:7564 Replies:7 FollowUps:2
Where in the Prado can I install the main radio and cradle as there seems very little room under the dashboard. Would under drivers seat be a good place. I can put the remote head under ashtray in the front of dashboard.
Reply By: Member - Stan (VIC) - Monday, Sep 05, 2005 at 21:54
The radio crews to the bottom of the ashtray, the remote head goes
behind the glove box.
AnswerID: 128482
Reply By: joe1 - Monday, Sep 05, 2005 at 22:11
I have a hilux 2000mdl and had the same prob,I mounted the main unit under the passenger's seat and used silicon to glue the remote head under the ash tray,there for if you ever want to remove it you havent got any screw holes.
Have also used the same setup on my boat with radios onto alloy and they are still intact.
Joe1
AnswerID: 128495
Follow Up By: geocacher (djcache) - Tuesday, Sep 06, 2005 at 00:32
I'd rather have screw holes than silicone. You can never get the crap off.
The head is so small and light that the genuine brand name self adhesive velcro will hold it, and you can get that off. Adhesive included.
Word of warning. If you mount radio gear down low like under a seat, and then get stuck in the middle of a river, don't expect to be able to call for help. :o)
Been there got the pictures to prove it....
FollowupID: 383149
Follow Up By: Boc1971 - Tuesday, Sep 06, 2005 at 09:12
Im guessing your car will never see deep water joe - ;)
Frank
FollowupID: 383166
Reply By: Member - Drew T (VIC) - Tuesday, Sep 06, 2005 at 07:26
See posts 21450, 17878, & 14556 where this has been discussed before. Whilst I have put the main unit under the glovebox, i can recall reading a post where someone said nothing electronic should be fitted here because it can interfere with some of the cars electronics?? I personally haven't had a problem though
AnswerID: 128529
Reply By: roblin - Tuesday, Sep 06, 2005 at 10:49
Yayd,
I have just gone through this process. The GME folk told me that they fit them in the left hand kick panel area behind the engine ECU. Unfortunately, the DTronic takes up this space and radio did not fit.
I ended up pulling the centre console out and fitting the radio between the front of the centre console storage bin (separate piece) and the next section of console (the piece with the cup holders in it).
There is ebough space although you will need to place the bracket so that you can slide the radio in and out. To get the radio out, you need to release the handbrake otherwise the lever, when up, will not let you slide the radio into the mounting bracket. I then carefully and neatly drilled a series of holes (in a circular pattern) in the centre console just above the drink holder space for speaker output. I just measured the radio speaker postion and the speaker size and transcribed it to the console. I then covered the console area in masking tape, scribed the circle, divided it by 6 (diameter wise) and had a smaller innner circle as well. Where the diametr (chords?) crossed the circles I had a neat template for drilling. It all fits very nicely and even my missus thought it looked professional.
The remote head is mounted below the ash tray/cigarette lighter position with the bracket screwed to the surface directly below these items. This way you don't see too many drill holes if you remove it. It is a pain in the A to get a drill in and position it correctly. Use a bit of double sided tape to hold the bracket in place whilst you drill then crew it up. The remote head cable is then run between the forward centre console piece (behind the many switch blanks and 12 V outlet) by filing a neat round slot in the forward edge of the lower console panel (There are 6lower console panels - the storage bin, a cover over the handbrake and gear levers, another lower section around the gear levers, the forward section with balnking plugs and two side pieces that run into either front seat kick panel area along the transmission tunnel).
I got my 12V for the radio from the accessory plug (cigarette lighter would also have worked) and screwed the mic mount to one of the switch blanking plates so that I can slide the mike in sideways and it then sits in the forward section of the lower console next to the accessory outlet.
It took some exploration to find all of this out but it works a treat. the speaker output is right next to you and the rest is easy access. The lower console is a combination of pull off trim strips then screws and the like. It is not hard to do.........once you know how!
AnswerID: 128568
Reply By: 120scruiser - Tuesday, Sep 06, 2005 at 21:19
Not sure if this helps but I mounted mine in a roof console from department of interiors in Carlton Sydney.
They were great and custom made it. They used the original interior lights and sunglass holders.
There is heaps of room to rum wiring etc through the roof and its easy even up the pillars. I like it up in the roof as it gets it out of the way.
AnswerID: 128730
Reply By: joe1 - Tuesday, Sep 06, 2005 at 22:09
Nah Frank,the boat only see's deep water
AnswerID: 128742
Reply By: atoyot - Tuesday, Sep 06, 2005 at 22:48
Mines mounted behind glovebox (100 series), with remote head mounted on small bracket under rear view mirror mount. I have a mike extension and extension speaker running to console, so there are no un-necessary cables hanging and it is very convenient.
AnswerID: 128756
