Hilux 05 Tyres
Submitted: Tuesday, Sep 06, 2005 at 08:48
ThreadID: 26175 Views:5633 Replies:4 FollowUps:5
G'Day All,
Picked up my new SR (no flares) Hilux last Thursday and started messing around with the tyres. I tried the 90 series Prado rims with 235/85/16 and they stick out of the guards to far and the front brake calliper is extremely close to the rim, I could only get a "12 thou" (0.3mm) feeler gauge between rim and calliper.
So I have decide to get tyres to fit the 6" wide standard rims. I am looking at a 215/85/16 (31.4") Cooper ST, this would give a speedo change of 5%.
Has only one with a 05 V6 auto Hilux have larger than standard rolling diameter tyre and how does it effect performance as I love how it goes now and I don't want to change it to much?
Reply By: Stoney - Tuesday, Sep 06, 2005 at 14:34
Sorry,
I made a mistake with the tyre size, a 215/85/16 Cooper ST measures 30.48 inches
AnswerID: 128608
Reply By: time waster - Tuesday, Sep 06, 2005 at 16:50
i fitted the 90 series prado rims (the base model prado)to my sr 05 it is very close to front brake calliper but have done 7000km up to birdsville accross to alice and to problems rubing
AnswerID: 128637
Follow Up By: Stoney - Wednesday, Sep 07, 2005 at 06:37
What size tyres are you running? and if they have a bigger diameter than standard how has it affected your wagon?
FollowupID: 383360
Reply By: friar - Wednesday, Sep 07, 2005 at 11:22
Hi Stoney
I am running 215/85/16 st on 6''prado rims on a
3ltr hilux with after market turbo,it does affect the power on hills a little, but more than makes up for it dropping cruising revs to 2600 at 100 kys, I have driven the new hilux ,I doubt that you would notice it with the new motor, will be interested to hear peoples comments on this as I am thinking of putting my rig in on a new one,it will also help with ground clearance,with a bit of suspension mod it might get back to ground clearance of my model.
AnswerID: 128825
Follow Up By: Stoney - Wednesday, Sep 07, 2005 at 11:46
Friar,
Thanks for the reply, I have the V6 (175kw) I agree with you that the bigger tyres (approx 1.5" diameter larger) would not make much difference. I am also hoping that a lift kit and larger tyres will sort out the clearance.
FollowupID: 383401
Reply By: time waster - Thursday, Sep 08, 2005 at 08:35
the biggest tyre size they would fit is 225/75/16,haven't noticed any differece in driving.
would of liked wider rims but didn't want to have to put flares on.
AnswerID: 129010
Follow Up By: Stoney - Tuesday, Sep 13, 2005 at 08:19
I am starting to think that the 225/75/16 is the size tyre I will go for as it appears to be a common size and I don't really want to change the performace. Before I get tyres I am going to use my mates 31/10.5/15's to see how it affects the car
FollowupID: 384246
Follow Up By: Member - Norm C (QLD) - Tuesday, Sep 13, 2005 at 10:19
Stoney, let us know how the 31/10.5/15s go. I've got 265/70/15s on my SR5 at the moment. Next time I'm looking to go a bit bigger for some more clearance and thought the 31/10.5/15s might be about the biggest I could go.
10.5 will be a bit wide without flares on the SR I think. After market flares shouldn't be too expensive if you want the wider tyres.
FollowupID: 384266
Follow Up By: Stoney - Tuesday, Sep 13, 2005 at 11:46
Norm,
I agree, I think the 10.5" tyre will be to wide with out flares.
I am only trying the 31's just to se how it affects on road performance.
If there is not much of a difference in performance I can get the Cooper ST 215/85/16 as this is very similar rolling diameter to the 31's
FollowupID: 384280
