Drawer Slides
Submitted: Tuesday, Sep 06, 2005 at 11:17
ThreadID: 26187 Views:13390 Replies:11 FollowUps:9
Looking to build my own drawer system. Where can I get some drawer slides from in the eastern suburbs of Melbourne.
Thanks.
Reply By: Member - Banjo The First (SA) - Tuesday, Sep 06, 2005 at 11:25
Sometimes its good to be in SA - bloke I work with found some nice HD ball race types - chromed - $18 the pair ! - at one of those machinery and tool type disposal places - they look good - not tested yet.
AnswerID: 128575
Reply By: Truckster (Vic) - Tuesday, Sep 06, 2005 at 11:25
Carac in Dandenong
AnswerID: 128576
Follow Up By: Jimbo - Tuesday, Sep 06, 2005 at 13:17
Vastly overpriced.
FollowupID: 383216
Follow Up By: Truckster (Vic) - Tuesday, Sep 06, 2005 at 14:02
always get club discount :D never bothered buying much in there...
FollowupID: 383225
Reply By: Member - Jack - Tuesday, Sep 06, 2005 at 11:56
Got mine from eBAy. Might be worth a look.
Jack
AnswerID: 128581
Reply By: Shaker - Tuesday, Sep 06, 2005 at 12:09
Hafele in Dandenong have a huge range.
AnswerID: 128583
Follow Up By: Drew - Karratha - Tuesday, Sep 06, 2005 at 12:21
http://www.hafele.com.au/isapi/online/tchff/tchff.asp
100 kg load rated - around $100 a pair from memory. I used them for roller drawers for the back of my 80 series and they work great.
FollowupID: 383207
Reply By: Jimbo - Tuesday, Sep 06, 2005 at 13:19
UES in Dandenong.
VERY strong units.
AnswerID: 128593
Follow Up By: ChrisB - Tuesday, Sep 06, 2005 at 13:30
Do you have a street address or web page?
FollowupID: 383218
Follow Up By: MikeyS - Tuesday, Sep 06, 2005 at 14:45
Häfele Australia Pty. Ltd.
8 Monterey Road
Dandenong, Victoria, 3175
Tel: +61 (0)3 9212 2000
Fax: +61 (0)3 9212 2001
E-Mail: info@hafele.com.au
I've used 2 pairs of Accuride slides, made (or distributed) by Hafele, on for a drawer and one for a fridge slide. Smooth as silk and much better travel than a normal fridge slide.
MikeyS
FollowupID: 383241
Follow Up By: Jimbo - Tuesday, Sep 06, 2005 at 19:10
Chris,
Sorry the earlier message was brief, I just popped home for 5 minutes.
The slides are different to the Hafele or TJM which are 3 stage with ball bearings. The UES is 2 much stronger bars, looks a lot more robust to me. I'll be getting some in a couple of weeks.
www.uesint.com
info@uesint.com
38-40 South Link, Dandenong South
PH: 8787 3100. Talk to Paul.
Jim.
FollowupID: 383288
Reply By: Member - Brian (Gold Coast) - Tuesday, Sep 06, 2005 at 16:38
Hettich is another good slide, about $115 from memory for a 100kg rated at 900mm extenesion slide kit. I got mine from Mermaid Distributors here at Southport, but Hettich are all over the country
AnswerID: 128634
Follow Up By: Member - Phil G (SA) - Wednesday, Sep 07, 2005 at 12:01
Yep,
I've used the Hettich slides for three drawers in the back. I don't intend on filling with anything heavy, so used the #5632 runners which were 650mm and rated for 45kg, and only cost $42 a pair. They work fine. Got tehm from Galvins in Adelaide.
FollowupID: 383403
Reply By: Brad G (SA) - Tuesday, Sep 06, 2005 at 19:05
Ebay Search Mate
Ebay Search - Drawer Slides
Cheers Brad
AnswerID: 128685
Follow Up By: Brad G (SA) - Tuesday, Sep 06, 2005 at 19:06
P.S. I've bought a set of these and they haven't failed yet.
FollowupID: 383286
Follow Up By: Bitsumishin - Mike (WA) - Tuesday, Sep 06, 2005 at 20:42
Brad, I notice they only come out 44cm. Doesn't sound like much. Do you have short drawers or how do you get to the stuff at the back?
FollowupID: 383304
Reply By: Croozer - Tuesday, Sep 06, 2005 at 20:46
Might be worth trying a local kitchen manufacturer (not one of the big ones). I have a mate who builds kitchens and he got me a couple of sets of over extending, ball bearing, heavy duty slides. From memory about $100 per set but are brilliant.
I'm in Sydney so can't really help you in Melb.
Stuart
AnswerID: 128718
Reply By: Member - Phil G (SA) - Wednesday, Sep 07, 2005 at 20:50
The 100kg sets on Ebay are identical to the ones I ran for about 3 years on the Prado. I had the ones that were 800mm long. Main criticism was that the drawers do not extend out full length; and that theres a lot of vertical play when the drawer is closed. Also its strongly recommended that you don't weld them because you'll butcher the nylon rollers. The positive is that they are easy to fit for wooden drawers, and drawers can be removed very easily.
As mentioned above, this time I went for the 45kg Hettich runners (KA 5632) in the 650mm length at $42 a pair. They are nice and tight, dual stage, so come out full length.
The weight is the rating with the drawer fully out. When fully closed, the runners would be considerably stronger, so I'm not expecting any issues with my 45kg runners which will carry about 20-30kgs in each drawer.
phil
AnswerID: 128950
Reply By: prado_95 - Thursday, Sep 08, 2005 at 21:34
I wonder if your interested in an unused draw set (complete to fit Landcruiser - but easily modded for other similar vehicle).
prado_95@yahoo.com
AnswerID: 129182
Reply By: Barry Crocker - Thursday, Sep 15, 2005 at 04:32
Try Howard Silvers, got a good set of slides from them last year for $100 a pair and rated to 100 kgs. worked great for drawers in my 80.
They climb up in lengths of 10cm a time and will long outlast the rest of the drawer stucture.
The company are based in sydney but sent them up to their rep in brisbane for free and i picked them up, i'm sure they will have a rep in melbourne.
Used 90 cm slides for back of my 80 with cargo barrier fitted.
cheers barry.
AnswerID: 130168
