Trailer brakes
Submitted: Friday, Sep 09, 2005 at 14:46
ThreadID: 26309 Views:9141 Replies:5 FollowUps:4
Can anyone tell me what override brakes are on a trailer. I have hydraulic disc brakes on a camper are these the same thing or different?
Reply By: Vince NSW - Friday, Sep 09, 2005 at 15:16
Override breaks are activated by the hitch either compressing a break cylinder or acting on a cable system, It is a manual system as opposed to an electrical one.
I would think if you have discs it would not be override.
Vince
AnswerID: 129321
Follow Up By: Member - DickyBeach - Saturday, Sep 10, 2005 at 06:55
I have a Kimberley Kamper with override brakes (as described by Notso, below) and the brakes are discs not drums.
FollowupID: 383885
Reply By: Notso - Friday, Sep 09, 2005 at 15:21
Easy to check it mate.
If they are over ride brakes there will be a small resevoir of brake fluid just back from the coupling on the trailer draw bar. You will also see a section of the coupling just beyond the tow ball or whatever connects you to the motor vehicle that slides back and forth as you apply the brakes. This actuates the master cylinder and applies hydraulic pressure to the brake cylinders on your trailer wheels
AnswerID: 129324
Follow Up By: Vince NSW - Friday, Sep 09, 2005 at 15:24
I Agree, but my one is cable not hydraulic. A very good word picture of the set up.
FollowupID: 383792
Follow Up By: garrycol - Friday, Sep 09, 2005 at 16:07
They don't have to be hydraulic - some can be mechanical with a cable from the overide mechanism to the brakes
FollowupID: 383804
Reply By: Austravel - Friday, Sep 09, 2005 at 15:52
Thanks all.
AnswerID: 129330
Reply By: Member - John C (QLD) - Friday, Sep 09, 2005 at 17:55
Our trailer sailor trailer (!!) had overrider disc brakes working off a cylinder at the back of the trailer coupling.
More common is the cable and drum overrider brakes working off the handbrake lever at the back of the trailer coupling.
AnswerID: 129356
Reply By: cmilton54 - Friday, Sep 09, 2005 at 18:35
Their should be a over centre latch on the coupling to engage for reversing to lock brakes out. over ride only ever work when in difficulties.
Charlie
AnswerID: 129361
Follow Up By: V8troopie - Saturday, Sep 10, 2005 at 00:45
Yes, for these brakes to work the trailer has to push the car. This can be detrimental when the trailer approaches the weight of the towing vehicle and you brake on wet roads.
Override brakes also only hold when you are stopped facing downhill, they do nothing if you are stopped facing uphill and the car's handbrake might not be up to holding the car and trailer.
I much prefer the electric brakes where the trailer brakes can be set to come on slightly before the towing vehicle's brakes.
Klaus
FollowupID: 383883
