watts to amps
Submitted: Friday, Sep 09, 2005 at 16:53
Member - Ross H (QLD)
I have a 12v mozzie coil that uses 8watts. Was just wondering if one of you educated sparky type people could tell me how many amps that would be.
Thanks in advance
ross
Reply By: hl - Friday, Sep 09, 2005 at 16:59
About .6 amps at 13.8V
129341
Follow Up By: F4Phantom - Friday, Sep 09, 2005 at 17:07
just thought you may also want to see it this way.
W=AxV
A = W/V
V = W/A
383818
Reply By: Bob of KAOS - Friday, Sep 09, 2005 at 17:02
Power(in Watts) = Voltage (in Volts) X current (in Amps).
So current = Power/Voltage or 8/12 which is 0.66 Amps
129342
Reply By: Notso - Friday, Sep 09, 2005 at 17:02
Divide your watts by your volts.
8/12 should work out at about .66 of an amp. Most "12 volt" systems are a bit more than that so the eqaution will vary depending on the state of charge of the battery or whether it is running off a "12 Volt" power supply which will be up to about 14 volts depending on the overall load.
129343
Reply By: Member - GeeTee (NT) - Friday, Sep 09, 2005 at 17:05
Hi, The formula for Amps is P/E, where P is power in watts, E is voltage.
Gives you 8 divided by 12. Which equals .666 A or approx 666 MilliAmps.
Check out this Link
Hope the link works and the info is useful to you.
GeeTee
129345
Reply By: Member - Ross H (QLD) - Friday, Sep 09, 2005 at 20:10
Thanks for all the replies. I am off
camping in the morning and only have 115ah deep cycle just for lights,mobile charger and now mozzie coil will
well and truely last a week. Straddie hear I come.
regards
ross
129376
Follow Up By: Stuart - Saturday, Sep 10, 2005 at 12:38
Ross, just wondering how
well the 12volt mossie coil works?
Cheers and hope you enjoy your holiday.
383911
