Advice needed for 2003 Hilux V6 3.4L
Submitted: Monday, Sep 12, 2005 at 16:02
ThreadID: 26385 Views:11285 Replies:10 FollowUps:15
Afternoon,
I'm checking out a 2003 Hilux V6 3.4L single cab chassis[50k on the clock]. Are there any issues with this unit I should look out for? What's the economy like around town?
TIA.....eng
Reply By: See You - Monday, Sep 12, 2005 at 17:18
Three words for you. LPG.
They suck juice like a Balinese princess.
AnswerID: 129701
Reply By: Member - Bill S (NSW) - Monday, Sep 12, 2005 at 19:42
Two words for you====FIT A FITCH And thats SOUND advice from one who KNOWS,the last one I fitted now uses two litres less fuel per 100klms driven.
BILLS
AnswerID: 129738
Follow Up By: D-Jack - Monday, Sep 12, 2005 at 20:13
Bill
How much diesel will one save on my 99 TD Jackaroo manual?
FollowupID: 384194
Follow Up By: See You - Monday, Sep 12, 2005 at 20:53
Fit a Fitch is 3 words. Count them:
1. fit
2. a
3. fitch
FollowupID: 384201
Follow Up By: D-Jack - Monday, Sep 12, 2005 at 22:19
So Bill, My Jackaroo is constistently getting 12.3-12.6L/100kms. Are you saying that fitting a Fitch will definitely get it under 12.0L/100kms? There is obviously nothing wrong with the vehicle, these figures are common to TD Jacks with bigger tyres and roofracks. But if it doesn't return better figures, will you be telling me it is because of a mechanical problem??? And are you willing to offer a guarantee that it will work excluding fitting?
D-Jack
FollowupID: 384215
Reply By: Wok - Monday, Sep 12, 2005 at 19:49
This is not good :(.....What figures are you getting?....
eng
AnswerID: 129741
Follow Up By: Member - Bill S (NSW) - Monday, Sep 12, 2005 at 22:09
FIT one word A one letter fitch the second WORD. The majoraty of diesels fitted are saving at least a litre of fuel for every 100klms driven for the next 400,000klms.
Into the bargain putting 70%less pollutants into engine oil and 50% less pollutants emitted from the exhaust
.My 80srs is returning8.7 to 9.6 kilometers per litre.Or as mentioned before by those using litres per 100klms mine equates to 8.7323 and 9.6421. i can answer questions about this product on this forum but not post anything.
And believe me members I do know just what I am saying about this product as I have fitted a thousand plus vehicles,all rescipients and users happy with it.
The only time a failure has been noted is when the fitted vehicle has a fault,fault rectified product working.
FollowupID: 384210
Follow Up By: Wok - Tuesday, Sep 13, 2005 at 07:12
Bill,
The V6 is ULP, not diesel....any performance figures for ULP? Had a look at the website, how is the unit fitted in the fueltank? [ as recommended for petrol vehicles]
FollowupID: 384239
Follow Up By: Member - Bill S (NSW) - Tuesday, Sep 13, 2005 at 09:23
Wok.I checked out your comments in regard to what is stated on the website, I do not necessarily recomend drop inns but rather the in line unit as it can be transfered if you change cars a few years down the track. Where as if you had dropinns installed it is unlikely you would remove the tank to retreive them. The wording on the webb will be amended shortly.
BILLS
FollowupID: 384258
Follow Up By: See You - Tuesday, Sep 13, 2005 at 13:42
Hi Bill, or is it Dill. A is a word as well as a letter. You can use the letter a as a word in scrabble too. If you could use letters (that were not words) by themselves in sentences then a whole lot of sentences would not make sense. Do you understand.
Here is a sentence made of letters does it make sense to you????
G e t a b r a i n y o u s t u p i d g i t w h a t d i d y o u l e a r n e i n s c h o o l n o t m u c h i b e t a p a r t f r o m s t i r r i n g u p b o y s a n d p l a y i n g w i t h y o u r w i l l y b e h i n d t h e b u s h
FollowupID: 384305
Reply By: AndrewW - Monday, Sep 12, 2005 at 21:54
I have a 2002 3.4 V6 Dual Cab. When I first bought the vehicle running around on the HT pattern 255/70R15 tyres, I was getting between 12 and 13 l/100km, consistently. Towed a camper trailer with it from Melbourne to almost he SA border and back, and it got a consistent 14 - 15 l/100km, which is not bad in my books.
I have since fitted 31" tyres, which is an inch or so bigger than standard, and have noticed that the economy has jumped up to 14 l/100km unloaded.
I also have a set of 31" MTRs as wells as some ATs, and they suck more power and use more fuel again.
If you are happy to run the standard sized tyres (equilavent to 30x9.5x15) then they seem to be able to return in the 12 - 14 l/100km range, depending on loading and driving style. If you are going for bigger tyres or more agressive tread patterns, it will use a lot more juice. Hard slow off roading will also chew the juice. Worst I have had is about 30 l/100km, but that was extremely slow hard going, over a 200km section of the outback, and very heavily loaded. Normally with the 31" tyres I expect to use up to 20 l/100km offroad, maybe a couple of litres less per 100km. I never really did a lot of offroading on the 30" tyres, but the little bit I did, it did use less fuel.
I have found that the vehicle and gear ratios are well setup for the original size tyres, but it has suffered performance wise, and fuel economy wise with the only slightly bigger tyres. If I had to tow anything a lot, I would go back to the smaller tyres for ATs.
AnswerID: 129773
Follow Up By: Wok - Tuesday, Sep 13, 2005 at 07:01
Thanks Andrew, I can work with those figures. Sounds like original tyre size is the way to go. The economy isn't much different from the current V6 4L.
FollowupID: 384236
Reply By: gramps - Monday, Sep 12, 2005 at 22:04
Wok,
I have a 2004 V6 Extra cab (manual) with canopy, steel bullbar etc etc and over 18months and 38k have averaged 11.7l/100k. Most of that has been on sealed roads but around 7k on dirt, sand, and cross country stuff. I run the standard split rims and rubber. The worst figures were 16l/100k fully loaded for some parts of the track from Innamincka to Mt Dare.
AnswerID: 129775
Follow Up By: Wok - Tuesday, Sep 13, 2005 at 07:08
Thanks Gramps,
This unit I'm looking at has an alloy bar[ lighter!].I have got my "take-away gear" to minimum this days so hopefully it shouldn't guzzle too much on trips!
FollowupID: 384237
Reply By: Member - Bill S (NSW) - Tuesday, Sep 13, 2005 at 09:15
HI WOK To answer two questions
1/ Yes this product works equally well with any fuel
2/ Yes this product has a complete guarantee for 90days and honered
3/ I am fitting up a 2004 v/6 pajero today I will have the owner post his report after he finds out just what it does{if he will I dont know who he is till I meet him}
Now I would like to thank those asking sensible question in relation to this product
which all can see is advertised on this forum.
I ask this question of forum members after fitting over 1,000 of these units why is it I have only had four negative reports????
BILLS
AnswerID: 129823
Follow Up By: chris-a - Tuesday, Sep 13, 2005 at 16:27
OK OK what is the price to fit one to a Holden rodeo 03 mod T/d 3lt thank you chris
FollowupID: 384342
Reply By: Member - Bill S (NSW) - Tuesday, Sep 13, 2005 at 18:48
HI Chris, F300 is the inline unit to fit yours at a cost of $510 plus fit or the option is dropinns at $300.
Had a call from a guy today who fitted a F300 to his v/8 landcruiser claims fuel usage has dropped two litres per 100klms driven. check out the website find a agent near you and go for it remember it is guaranteed for 90 days,you have NOTHING to risk, everthing to gain.Once again thankyou for a intelligent question.
AnswerID: 129923
Follow Up By: Member - Bill S (NSW) - Wednesday, Sep 14, 2005 at 18:56
A bit of information for those concerned with fuel prices.reported today a recent purchaser of a F300 fitted to his 100srs V/8 petrol fuel usage has dropped by two litres per 100klms driven,same story with a guy who has a F300 fitted to his Jeep Cheroky. Will have a report on one fitted to a V/6 Pajaro shortly yes and thats two V/8 cruisers smart people are fitting to their vehicles.
BILLS
FollowupID: 384568
Follow Up By: Member - Ian W (NSW) - Wednesday, Sep 14, 2005 at 20:15
Visit the Fitch Website!
Right down in the bottom right corner there is a weeny little title called "Legal Disclaimer"
Read the last sentence of paragraph six!
There you will find that the guarantee in fact guarantees that there IS NO GUARRANTEE with regards consumption or emissions.
Now if your prepared to take the plunge to try one of these suckers and then return it, your still up for the cost of fitting and removing.
If you have had to cut metal fuel lines to fit it would be a messy job to restore your fuel supply line.
Bear in mind also that there have beens claims that "it" can take up to three months to show results because it might have to clean out your fuel system first! - Theres 90 days out of your warranty
Now these damn things are supposed to work on all fuels - If so why are they not fitted to heavy vessels - marine architects go to great extremes designing hulls to pick up as little of half off one percent in fuel savings.
Sorry! But can,t we bury this damn thing for once and all
Ian
FollowupID: 384585
Reply By: Member - Bill S (NSW) - Thursday, Sep 15, 2005 at 08:37
HI Ian , Mate you might as well bury this thing until you move into the advances made in this feild,my suggestiobn to you is to contact me and I will fit this for NOTHING so that you at least will be making statments that have some resembalance of truth.Forget about whats written on paper or comp and have the fortitude to try it yourself then comment.
Regards BILLS
AnswerID: 130194
Follow Up By: Member - Ian W (NSW) - Thursday, Sep 15, 2005 at 18:57
Bill,
Is that SUPPLY & FIT or is it SUPPLY ONLY?
Please, which part of my follow up did not have "resembalance of truth" (sic).?
Please advise where on the Fitch Website I can find reference to the 90 day warranty as I must not be looking in the right area.
Ian
FollowupID: 384733
Reply By: Member - Bill S (NSW) - Thursday, Sep 15, 2005 at 19:42
HI IAN, Mate thanks for your enquirie this product is genuine it really saves the average motorist more than a litre of fuel for every 100klms driven.
If you are genuine with your enquirie email me on billfitch@1earth.net,and I will answer you with the truth.
It appears there are people on this forum who continuasly want to bag what they dont understand without justifaction,my remarks on this are brought about by the feed back I recieve from users of the product and of cource my own tests carried out over some four years on various machinery.It is only a matter of time when the crittics find out for themselves just what occurs after fitting that I expect appolagies will appear for their rude remarks.Mate lets have a chat without the interference of sceptics.
Regards BILLS
AnswerID: 130278
Follow Up By: Member - Ian W (NSW) - Saturday, Sep 17, 2005 at 23:12
Bill,
Where can I find reference to the 90 day guarrantee on the Fitch Website,
I still can't find it.
This is now my THIRD request!
Ian
FollowupID: 385100
Reply By: Member - Bill S (NSW) - Monday, Sep 19, 2005 at 09:49
HI Ian NSW,Mate the 90 day money back statment is on every bit of litrature and phamplet we have.I dont live by the webb site i live by what is real what I see and percieve to be real which is this product.Sorry I cant answer your question in locating this information on the computor because I dont know simple.But I do know that after fitting so many returns are not a problem.
Regards BILLS
AnswerID: 130762
Follow Up By: Member - Bill S (NSW) - Tuesday, Sep 20, 2005 at 20:25
Hullo Again IAN.If you go to the site and under information then go to applications you will see it clearly stated after every applications. A guy rang me today and informed that his BA falcon has gone from 590klms per tank to 780 after fitting a F6t kit to his ute some time ago, now if this is not savings what is?
Regards BILLS
FollowupID: 385430
