05 Dual Cab Hilux lift Kit
Submitted: Tuesday, Sep 13, 2005 at 12:08
Stoney
G'Day All,
I want to get a lift kit for my Hilux in the next month and I would like to know what other people have done.
I have been emailing Darren from ATS about his kit, but I would like to know what else is out there.
ARB say there kit is 30-40mm lift, but does it actually go higher once it is installed.
TJM say there kit is 50mm lift, but won't be available for one month.
I would prefer to get the 50mm lift but I like the way ARB has 3 different setups depending on what is on the vehicle.
I do not have a bullbar and will not get one because I will have troubles fitting the car in the garage and I have a canopy, so I want is a soft setup.
Thanks Carl
Reply By: Member - Norm C (QLD) - Tuesday, Sep 13, 2005 at 12:17
I've got the ARB (OME) medium kit. Achieved 43mm lift at front and 70mm (unladen) lift at back. Also ripped off the factory alloy side steps and replaced with steel ones up under the sill. Improves side clearance another 70 odd mm. Over time with a bit of sag, it will come down a bit (but this is true of all suspensions with load).
The medium is rated at 250KG constantl oad (from memory). If you have canopy and regularly carry a bit more (recovery gear, tools, perhaps fridge etc); medium is probably the one.
The ride remains comfortable on road and clearance is much improved off road.
I'll probably change to tyres to 31/10.5/15s when current Coopers wear out. This will add about another half an inch.
129859
Follow Up By: Stoney - Tuesday, Sep 13, 2005 at 13:39
Hi Norm,
How does the ride compair to standard and do you have any extra weight up front?
ARB suggested to go for the soft setting at the front and the medium setting for the rear. I think the only other accessory I may add up front is a an extra battery, I want the front to stay fairly soft.
I love how
well these cars (trucks) ride as standard so I don't want to stiffen the front end up to much.
Carl
384303
Follow Up By: Member - Norm C (QLD) - Tuesday, Sep 13, 2005 at 14:41
I don't notice much different. Might be a bit stiffer, but hard to detect. Wife says she feels a bit more body roll when cornering, but I don't notice it.
I've got an extra battery up front and have a steel bull bar on order. In the back I always have the canopy, drawer unit, tools, recovery gear, fridge, 20 lt
water can, gas bottle and sundries. Then load up (including up to 200KG ball weight for CT) for trips.
If you mostly use it on bitumen, soft up front is probably good. If you do off roading I'd go for medium (and a bull bar; not only for protection, but also to improve approach angle). Looks better too I reckon, but that's just an opinion.
384324
Follow Up By: Stoney - Tuesday, Sep 13, 2005 at 15:12
Norm,
I would like to get a bullbar but I am concerned about running out of room in my garage, the garage is only 5.4m long and the Hilux is quite long. I must have it in the garage because there is nothing better than a remote operated garage door in the middle of winter when it is raining.
It sound like you have had good results with the ARB
suspension
384330
Follow Up By: time waster - Tuesday, Sep 13, 2005 at 15:56
norm,
where did you fit your brake controller on the dash, and the brand, also was it hard to wire up?
cheer's
384335
Follow Up By: Member - Norm C (QLD) - Tuesday, Sep 13, 2005 at 17:59
The Tekonsha Prodigy unit fits neatly into the ash tray holder. Had to find somewhere else for the small change, but that's not a big drama.
I've also installed a self made roof console with the radio (GME 4400) installed in it. I've run a microphone remote cable down and it comes out beside the brake control unit (ie through the back of the ash tray holder). This avooids the curly cord hanging in front of the mirror.
It is pretty tight behind the dash. You turn yourself in knots getting your head and hands in, but the old straightened out wire coat hanger helps a lot to get the wires through.
To get cables from behind the dash into the engine bay (radio antenna, reversing camera cable etc), there is a large rubber grommet behind the dash in front of the passenger
seat. It is pretty easy to get to. I pushed some wire through the edge of this and had no trouble getting all the wires I wanted through. I'll eventually silicon around the wires to make sure it is sealed.
384364
Follow Up By: time waster - Wednesday, Sep 14, 2005 at 16:09
thanks for that i will have to find another place as my cb is where the ash tray was.
384540
Reply By: Member - David B (QLD) - Tuesday, Sep 13, 2005 at 19:23
Hi Carl,
I went with 40mm King Springs in the front and left the rear standard, and have Bilstien shocks allround.
Dave.
129928
Follow Up By: Stoney - Wednesday, Sep 14, 2005 at 07:21
Hi Dave,
How does your Hilux now ride compaired to standard?
What brand bullbar do you have in the image?
Carl
384451
Follow Up By: Member - David B (QLD) - Wednesday, Sep 14, 2005 at 12:55
Hi carl,
Smoother ride over the rough stuff. The bar is a cheap Thai import.
Dave.
384515
Follow Up By: Stoney - Wednesday, Sep 14, 2005 at 14:24
Hi Dave,
How, who, when or where did you purchase the bar from?
It looks like the bar did not really add much length to the vehicle, do you have any idea how much further the bar sticks out compaired to original bumper?
I would be happy to have a cheap bullbar to improve the approach angle
384528
Follow Up By: Frank - Wednesday, Sep 14, 2005 at 17:59
Stoney
I too am preety keen on the bar, turns out it is being imported by Equipe Automotive in
Brisbane, however I would not describe it as a "cheap Thai import", at $1,495 it is actually $50 more than the ARB bar.
384560
Follow Up By: Stoney - Thursday, Sep 15, 2005 at 06:35
Frank,
I think you are right when you say it's not cheap, there is a place in
Sydney called Global 4X4 Accessories (
http://www.global4x4accessories.com.au/) and on there website they have similar looking bars for $590. I will contact them to se if they do a bar for our model Hilux.
384618
