Ball Adjustment Nut
Submitted: Tuesday, Sep 13, 2005 at 16:16
JMR
Could someone please elighten me on the exact purpose of the ball adjustment nut on a trailer?
Reply By: Patrol Freak (NSW) - Tuesday, Sep 13, 2005 at 16:28
to take up the slack with different size balls eg metric or imperial & wear.
129901
Reply By: Ian from Thermoguard Instruments - Tuesday, Sep 13, 2005 at 17:28
Yeah, as Mr Freak said, it's to take up any slack, due to wear and mnaufacturing tolerances. (But it's really not meant to adapt modern 50mm items to old 2" ones, IMHO. Only 50mm SAA certified balls and couplings should be used these days.)
Just don't do it up too tight or it will cause more wear. The way to use it is: couple to the ball as usual, loosen locknut, undo the adjusting screw until you're sure it's not touching the ball, then turn the adjusting screw inwards until it just touches the ball (finger tight), hold the adjusting screw screw and tighten the locknut.
Ian
129907
Follow Up By: JMR - Wednesday, Sep 14, 2005 at 09:47
Thanks very much for your help most appreciated.
384479
Reply By: geocacher (djcache) - Thursday, Sep 15, 2005 at 05:52
I can't beleive anyone didn't go for the inuendo answers on this one :o))
Some of you must be slipping?
Nudey?? Do you have a nut adjustment ball??
130172
