3.0l nissan
Submitted: Thursday, Sep 15, 2005 at 16:09
ThreadID: 26485 Views:3922 Replies:4 FollowUps:2
Not sure if this has already been posted. Maybe new info for those with the 3.0l nissans. Pinched of Yahoo's Nissan_GU_Patrol forum.
eRODUCT INFORMA nOJ:!
Service Technical Bulletin
05/01 2005 13:11 FAX
61 262852688
LENNOCK MOTORS
IlIOO1/001
First Published: 30th September 2004
Bulletin No: MAO4-001
Re: Revised Engine Oil Specification
Applied Model: Y61 & D22
Applied range: ZDJO Engines
Please be advised that the specification for the 011 fill on the ZD30 has been
revised. Engine
Oils that meet the specIfication lis~ed below are the only oIls that are
permitted for use in the
ZD30 Engine.
011 SpecificatIon: ACEA 83 or JASO DH.1
Nissan strongly recommend that a viscosity rating of 10W40 be used. For specific
viscosity
relating to ambient temperature ranges please refer to the viscosity chart in
the relevant
workshop manual.
Note: API CG-4 0118 must never be used In the ZD30 engine.
To support the revision in oil specification, Nissan has developed a
semi-synthetic 10W-40
engIne oil that meets ell the operational demands of this engine. The revision
of the new oil
specification is retrospective and will apply to all ZD30 engines.
The oil will be available from Nfssan Parts & Accessories in 51t and 200lt
Quantities using the
following part numbers.
51t- B3005-10W40PK
2001t- B3200..10W40PK
Authorised by:
R Bahn
Manager. Engineering Support
National Service & Engineering Department
'rhB inforTTlslion in this bullelln should not be I"terpre~d a& a baBi8 tor
claimo vnless so designated
~art numbers rsfamld tQ mtly "Ot always be immedietely ewillble
AlwlYI 0I'der parts rrom releYlrlt par'ts intDrmstion and "01 Ihi, bulletin.
NISSAN MOTOR GO. <AUSTRALIA) PrY. LTD. ABN. 54004563 1 ~6
L-ocked Bag 1450. Oal1denong South, VJC, :3154 Phone. (03) 97974111 Fax. (03)
97974400
www.ni$NI1.COm.au
Reply By: rob1 - Thursday, Sep 15, 2005 at 16:43
Thanks Austravel, I noticed the new semi synthetic oil last time I was at the Nissan Parts dept, and I think I'll give it a go next oil change. I have been using Nissan Diesel Oil (15W-40 CF 4, as recommended in the manual) for the past 2 years, change oil & filter every 5000 k's.
Rob
AnswerID: 130255
Reply By: Member - toohey - Thursday, Sep 15, 2005 at 16:54
gid'ay austravel
thanks for that info,shell were making the other one for nissan iwonder if their making this one
cheers toohey
AnswerID: 130256
Reply By: RussellP - Thursday, Sep 15, 2005 at 20:01
I get (got) my D22 serviced at Lennock. They use FMX oil, not their own. Same viscosity though. Curious?
Don't suppose there's a bulletin on the correct volume of oil?
regards
Russell
AnswerID: 130282
Reply By: Martyn (WA) - Thursday, Sep 15, 2005 at 20:26
Austravel,
The only thing with this is if you go on an extended trip and you buy a "fancy oil" you have to carry the "fancy oil" with you. I run a full synthetic and I had a problem with the filler cap (which I won't go into) after an oil change, I was so lucky I had five litres of the oil in the camper trailer when I noticed the problem on the back window of the vehicle. I asked at a country servo if they had any of this oil and they looked at me like I came from the planet Zod. Something to bear in mind when using synthetics.
Keep the shiny side up
AnswerID: 130290
Follow Up By: Willem - Friday, Sep 16, 2005 at 13:56
Hi Martyn
In the scheme of things would it really matter what type of oil you put in the truck, just as long as it got you home? Would it make such a big difference in wear and tear between pumped oil or synthetic oil.
I doubt it, but you tell me :o)
FollowupID: 384874
Follow Up By: Martyn (WA) - Friday, Sep 16, 2005 at 21:24
Willem,
If it was a case of get you home you are right of course anything will do, as long as it's oil of course. When you start mixing brands and also mineral oils and synthetics strange things can happen, the oil can congeal, it can laminate etc so the less stressful way of doing things is to take some oil with you, that was the point I was trying to make. The base oil is the same no matter what brand you buy oil is oil is oil it's the additives once it the oil is blended after its been processed from crude to oil that matter. Some additives don't mix.
My experiences and opinions of course. By the way how are you and hows the new bus going?
FollowupID: 384917
